Keyless Entry Codes
Old Dec 4, 2011 | 02:55 PM
  #181
Elk4me's Avatar
Elk4me
Thumbs up Re: 2002 keypad code
Originally Posted by 1956MarkII
Sorry- there are no stickers on the 2002s. The vehicle was originally delivered with a plastic card with the number on it, OR the originating dealer may have the number on file, OR you'll have to go to a Ford service department and have them pull the code out of the vehicle's computer, for which they'll charge anywhere from $0-50.00.
After reading this string of successes and failure to find the code I figured it was worth an attempt anyway. I found the code on my 2002 Explorer Limited just below the Pillar/ Seat-belt adjuster. It was on the module, but low and behold in their infinite wisdom the module manufacturer decided to place a yellow sticker stating "Programming Required" on top of the White Sticker with all the module information. I was able to remove the yellow sticker with a razor knife and long needle nose pliers enough to get see the numbers with a mirror and flashlight. I had to guess at one number because of the residue left from the sticker.
Old Apr 14, 2012 | 07:36 PM
  #182
Chaosracing's Avatar
Chaosracing
We just purchased a 2008 Expl XLT with keyless entry. Of course the code is not in the vehicle, and we bought it at a BMW dealership. They are going to try and contact the former owner for the code. But the owners manual says it is also on the module. Any ideas where that might be on a 08?
Thanks
Old Apr 14, 2012 | 10:07 PM
  #183
shorod's Avatar
shorod
In the 2008 the Remote Keyless Entry functions are performed by the Smart Junction Box (SJB). The SJB is listed as "under the dash panel, left hand side". It will likely be piggyback with a fuse panel. Check for a 5-digit number on a sticker down around the brake and parking brake pedals.
-Rod
Old Apr 15, 2012 | 12:40 AM
  #184
Chaosracing
I think I see the sticker....just dont know how in the world I am going to see the numbers.
Old Apr 15, 2012 | 10:17 AM
  #185
shorod's Avatar
shorod
Do you have an inspection mirror or borescope? Maybe a dentist friend that will let you borrow one of his little mirrors?
-Rod
Old Apr 15, 2012 | 12:29 PM
  #186
fordsbyjay's Avatar
fordsbyjay
Or get one at harbor freight for cheap.
Old Apr 15, 2012 | 08:36 PM
  #187
Chaosracing
Picked one up at Ace today...gotta get in there and see if I can find it and read it now.
Old Apr 17, 2012 | 12:36 AM
  #188
Chaosracing
Found it....thanks.
Old Oct 6, 2012 | 02:21 AM
  #189
Kad's Avatar
Kad
Hope this helps
Take vehicle to a Ford Dealer and they can hook up to it and provide you with codes in no time at all, I have had to do it with 2 vehicles
Old Oct 6, 2012 | 04:56 PM
  #190
shorod's Avatar
shorod
Sure, but typically the dealers charge quite a fee to access the keyless code. Finding the sticker on the module is free.
-Rod
Old Oct 10, 2012 | 12:57 AM
  #191
gaknak's Avatar
gaknak
Found the plastic card in the glove box. Thanks!
Old Apr 29, 2013 | 08:15 AM
  #192
Chugalug's Avatar
Chugalug
I had to get a key made for my 04 Explorer last week.
Went to the Ford dealer and they charged almost $90.
to make 1 key and they gave me the keypad code.
Old Apr 29, 2013 | 12:22 PM
  #193
Chaosracing
That sounds like the cost for the key. I had one made at a hardware store and they charged $75 for a key
Old Apr 29, 2013 | 02:09 PM
  #194
Chugalug's Avatar
Chugalug
I tried ACE hardware and they couldn't make one for mine.
He said they could make some.
Dealer said the computer had to be programed for my new key.
Old Apr 29, 2013 | 03:06 PM
  #195
Chaosracing
Had mine made at ACE, they just needed the existing key to program the new key. Took it out and tried it right away and no problems with it.
