Another Transmission Cooler Question
Old Dec 10, 2023 | 07:05 PM
Rainmaker1's Avatar
Rainmaker1
Hello all,
I looked around and see lots of questions around transmission cooler problems, using a 6.0 cooler, Mishimoto cooler, and I'm sure there are more. I don't tow heavy but I do drive quite a bit in Los Angeles traffic. I understand stop-n-go traffic can be hell on the 4R100. I want to add that extra protection for my city travels and towing up the Grape Vine that's 40 miles at an average grade of 4.5%, and gets up to 6% at an elevation of 1500-ft.
I want to be ready so....My question is, which one is the most reliable and best performing?
Old Dec 10, 2023 | 08:02 PM
BWST's Avatar
BWST
Got Data?
Many of us upgrade to the 6.0L transmission cooler when towing heavy. Your 2001 should already have the OTW cooler in the radiator and a small OTA cooler - these can be adequate for city driving and light to moderate towing. You could monitor your transmission temps using your phone, FORScan Lite, and an OBDII dongle - see where your temps hover.
A pre-emptive installation of the larger OTA cooler is not a bad idea. Documented my work on this in the thread below, starting at post 625:
BWST's F350 maintenance/upgrade thread - Page 42 - Ford Truck Enthusiasts Forums (ford-trucks.com)
Old Dec 10, 2023 | 08:24 PM
RacinJasonWV's Avatar
RacinJasonWV
Yeah what BWST said.
Important aspect in stop and go is to make sure to include the OTW cooler before the OTA cooler. The water cooler should be more effective than the OTA especially while fan speed is slow.
Either the 6.0 (Dorman) or Mishimoto would work for adding in the larger capacity OTA. The 7.3 version is like 1/3 the size of the 6.0 cooler. Huge difference.
Old Dec 11, 2023 | 01:13 PM
S-squatch's Avatar
S-squatch
I went with the mishimoto and have no complaints, straightforward swap. But I don't think it really matters which you go with.
Old Dec 12, 2023 | 01:41 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Yeah any of the 6.0 style coolers are way better than OEM.
Put a Magnefine filter between the radiator and the new cooler. If/when the trans lets go of some debris the filter will save the new cooler from getting clogged.
Old Jun 3, 2024 | 02:03 PM
Rainmaker1's Avatar
Rainmaker1
Thank you guys!
I went with the Mishimoto and had it installed last week. This past weekend I drove from Huntington Beach California to Friant / Millerton Lake with a 57 Chevy on a U-Haul trailer. Since I didn't have a transmission temperature gage I can't report any improvements but it made it over the Grapevine with no events. I've since just received a Isspro EV2 transmission temp gauge from Riff-Raff Diesel and hoping to have that in real soon.
When the shop shoed me the old cooler, I didn't realize that it had been upgraded to the 6.0 style by the PO. Had I known, I wouldn't have spent the $$. Seeing both in person I can say that the Mishimoto is about double the size of the 6.0 cooler so there's comfort there.
The only quest left is to where the the temp sensor should go, before the cooler or in the test/inspection port. Any suggestions are welcome.
Old Jun 3, 2024 | 02:45 PM
John in OkieLand's Avatar
John in OkieLand
wish I had seen this before I bought the 6.0 cooler...
but..... watching TFT from Price, Utah to Oologah, Oklahoma pulling 8,000 lbs over Loveland Pass, it never got above 180*
when I got into Kansas it got up to about 190ish, and that is way below the nominal 220* that the 4R100 is designed to operate at, all day long.
Old Jun 3, 2024 | 03:36 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
That depends on whether you want to know how hot the fluid can really get and scare yourself, or if you want to know the actual temperature of the transmission.
When the trans works hard, you can see temperatures over 300°F in the cooler line. Many people won't believe this, but that's normal. That's why there are coolers in the cooler line.
I recommend putting the sender in the test port. I've tested this with many thermocouples located throughout the transmission, cooler lines, and coolers, and determined that the test port gives a good average temperature of the transmission. The cooler line gives the highest possible temperature, the pan the coolest possible temperature, and the test port a good average of what the transmission is really seeing for temperature.
Old Jun 3, 2024 | 03:44 PM
FordTruckNoob's Avatar
FordTruckNoob
Thank you guys!
The transmission has a built-in temperature sensor that is reported via OBD. You can monitor that with FORScan or any other OBD gauge like a ScanGuage II.
Old Jun 3, 2024 | 05:59 PM
John in OkieLand
yup, labeled TFT, which I monitor
Old Jun 3, 2024 | 07:39 PM
Mark Kovalsky
The sender in the test port will usually be close to the TFT reading.
Old Jun 8, 2024 | 01:35 PM
Rainmaker1's Avatar
Rainmaker1
I believe Mark said it very well here. Thank you Sir..
At least it makes the most sense to me. I definitely do not want to scare myself and the actual transmission temperature is probably the best indicator. Plus, the test port is the easiest install. I have the Isspro trans temp gauge ready to install. Now I just need to have it installed and mount the gauge over the rear view mirror.
Old Jun 17, 2024 | 07:33 PM
Rainmaker1's Avatar
Rainmaker1
Is this the test port location (see arrow in the picture)?
The second picture is the temp gauge sensor. Does it look like the correct one and won't bottom out?
Old Jun 17, 2024 | 08:10 PM
Mark Kovalsky
That is the test port. The sensor looks a bit long, it might bottom. You need to put something in the port, such a a stiff piece of wire, to determine how deep it is.
powerboatr
Aug 21, 2021 12:30 PM
Phoenix02
May 25, 2018 03:48 AM
rvf62
Jul 9, 2014 09:04 AM
stimm32
Aug 25, 2012 12:53 PM
BigDog83
Aug 14, 2009 08:18 PM
