Hey Guys, I have a 2006 F350 6.0L with 92,000 miles on it. A week ago I got a P0283 code Cylinder 8 injector circuit high. Truck shook under acceleration and the idle was a little off. Replaced the injector and all was kumbaya for about 20 minutes of driving and then the code came back with the same issues. Dug back down to the injector to check connections and the hold down torque. All seemed ok. No broken rocker arms or anything strange. Any ideas why it was ok and then failed again?
I copied the description- Received from KT performance.
Item: Ford Motorcraft Fuel Injector, Ford (2004.5-10) 6.0L Power Stroke, Stock (4C3Z-9E527-BRM)
I took it to a shop but I'll update when something positive happens
The initial buzz before startup had a different sound- like a dead spot. I believe an official one was done that showed #8 not buzzing. Then they checked power to the injector and saw it wasn't receiving it.
