missing
Old Nov 18, 2008 | 11:01 PM
creed7276's Avatar
creed7276
missing
pulled code on my 2003 expy an it read p308and p208 i know p308 is the #8 cylinder misfire need help on the other code
Old Nov 19, 2008 | 12:52 AM
creed7276's Avatar
creed7276
how to solve code P0208
Old Nov 19, 2008 | 01:32 AM
alloro's Avatar
alloro
P0208 Injector Circuit Malfunction - Cylinder 8
This means either the injector for the #8 cylinder is bad or it's circuit has an open or short in it. This is also what is causing the misfire and code P0308 to be set.
I'd start by for checking the ohms of the injector for the #8 and comparing it to readings on a couple of other injectors. If the ohms are the same, the problem is in the wiring. If the ohms are different then it's a bad injector.
Old Nov 19, 2008 | 09:49 PM
creed7276's Avatar
creed7276
got up this morning and started the truck and the ses light was gone and it ran great for most of the day but tonight it started to jerk and shrudder on acceleration is this normal for an injector or cop.
Old Nov 20, 2008 | 12:09 AM
alloro's Avatar
alloro
Yes, it can work or not based on how hot the part gets.
Old Nov 20, 2008 | 09:06 PM
creed7276's Avatar
creed7276
thanks for the help replaced the #8 cop and its running great.
casanova76
1997 - 2003 F150
Mar 14, 2015 05:22 PM
englenn
New Member Introductions
Aug 4, 2014 12:15 PM
richyboy
2009 - 2014 F150
Dec 18, 2012 10:43 AM
ladiabla74
1997 - 2003 F150
Oct 20, 2006 07:10 PM
cannonfodder
Jul 19, 2004 09:50 AM
