Is CP4 still a problem?
Old Apr 20, 2026 | 10:12 AM
  #151
Overkill2's Avatar
Overkill2
Originally Posted by Painted Horse
We will never know, But it would be interesting to see how various factors influence the failures
So what are the contributing factors. Why does one pump with additives die at 50,000 miles and others run no additives and get 500,000 miles?
Are some guys just lucky enough to run Exxon/Mobile fuel and not need the additives? Based on Speed Lake's latest additve test. It appears that Exxon fuel( and some others ) have no need for additives
Others buy fuel from companies that produce only the Federal minimum.How many of the failuires were Lessor qualitiy fuel?
How many failures are due to DEF, GAS or Water in the fuel?
Do trucks in high humidty zones get more water in the fuel and have a higher failure rate? Would draining the water seperator more frequently help?
What about fuel from areas that don't get winterized as much as cold northern state? If you gell up, there is no fuel to lubricate the CP4. There always seems to be lot of failures after a hard freeze in the south.
What about High Alcohol products like Diesel 911 that somebody uses after Gelling up. What damage does Alcohol cause? It has no lubrication and actually strips lubrication
The actual additive in a fuel additives is a very small percentage. The rest of the additive is a carrier fluid. When people double or triple dose their fuel. What effect does that excess carrier fluid have? Another issue that Speed Lake mentions in his additive test. Use at the reccomened dosage, Don't double or triple does, More is not neccessarily better.
The list goes on and on, as What could cause these failures. I'm not believing it's all Bosch's fault. Ford builds 28,000 to 32,000 Superduties a month for the past 17 years, Thats over 6 million trucks. And no idea what the split between diesel vs gas.is. But you are probably looking at 4 million plus diesel trucks with CP4 pumps having been built.
I know two people who have had CP4 fail. First person's pump failed at 110,000 miles and he had never changed his fuel filters. Didn't know he even had them. Treated the truck like the gas truck he owned before.
Second owner traveling cross country and pulled in a BP station and just grabbed the Green Handle like he did at home and filled the tank with Gas.
Fantastic and insightful post as usual.
I would think choice of additive would also be a factor because as shown, not all additives provide above average lubricity to fuel.
As to fuel itself, I do not have high expectations of the fuel I get here in my home state of New York because we all know fuel bought around the country is not the same... I'm thinking cetane but obviously there's more to it than just that.
Trucks in cold winter areas will get affected when it comes in water in fuel as well as the warmed return fuel heats up the tank and the cold outside air meets the tank walls forming condensation which will make it into the fuel.
And the alcohol topic, there is such a thing as "bad" alcohol, meaning providing zero lubrication for the CP4 and "good" compounds containing alcohol (there are literally HUNDREDS of compounds that contain alcohol) that do or rather do not affect the lubricity of fuel. I do not know how to correctly explain this as I'm no fuel additive expert nor a chemist.
As to overdosing with additives, I believe IMO that depends on the additive and its function.
The owner of the 922k mile 17 6.7s CP4, which was original, came out in like new condition. He used PM22 *whatever the Motorcraft additive was and the additive that the makers of the Insane Diesel bypass filter market, and he always overdosed he stated...
I'd agree to the owner error of adding DEF or gasoline to the tank as contributing to possibly the majority of CP4 failures, but we will never know the exact numbers of legit failures, meaning ones who did all the proper maintenance and checked for water (or not) while not using additives (or used additives)... there are many, many different factors and situations I will acknowledge but to trust that the CP4 will not fail in the truck you drive which IMO, and like I've stated before, being the victim of a crime, <<<will NOT happen, is a little too trusting for my personal taste.
As always, YMMV and not everyone see this the same. I guess I like to be prepped and ready in case Mr. Murphy raises his ugly head.
Old Apr 20, 2026 | 12:31 PM
  #152
kayakingpoodle's Avatar
kayakingpoodle
Originally Posted by FishOnOne
It was also a warranty repair. If he had a DPK installed the warranty would have been denied.
Very likely, but there are people that have had warranty pay with the DPK, so it is not a guaranteed warranty denial.
Old Apr 28, 2026 | 04:11 PM
  #153
Bigfoot 4x4's Avatar
Bigfoot 4x4
For the Ford Powerstroke diesels, does the DCR conversion and emissions delete pretty much solve all it's problems? Anything else need to be done to achieve that 500,000+ trouble free miles ?
Old Apr 28, 2026 | 04:24 PM
  #154
Superdave71's Avatar
Superdave71
Bigfoot, there are some early 10speeds that had a CDF drum issue with the transmission, but that is less frequent than the CP4 failures, but still a known issue. I think they show up early in the trucks service.
Old Apr 28, 2026 | 04:39 PM
  #155
rufushusky's Avatar
rufushusky
I would throw a CCV reroute on that list too.
Won't guarantee a half a million miles trouble free but will help.
Old Apr 28, 2026 | 04:44 PM
  #156
Bigfoot 4x4
If someone has a 2020 - 2022 with the 10R140 transmission, can it be fixed by a specialist before any catastrophic failure or is it fundamentally flawed and the whole transmission needs to be replaced ?
Old Apr 28, 2026 | 06:45 PM
  #157
Superdave71
You can have the transmission tore down and the updated CDF drum replaced, but you’re doing a rebuild. If it fails, you need a rebuild just the same. It was a very small group with issues. I’d guess most have come to light by now. There is a bushing inserted (pressed) in the drum. Depending on the tolerance stack up of parts some had issues. Most did not.
Old Apr 29, 2026 | 03:11 PM
  #158
Overkill2's Avatar
Overkill2
Here's the owner of the 922k mile 6.7 Powerstroke and what he did...
Old Apr 29, 2026 | 09:48 PM
  #159
Bigfoot 4x4
https://youtu.be/s4FtN6lK9kw?si=pMu1VyrDmaRI1794
In the video, the owner mentions he installed a bypass oil filter. Any recommendations on brands and style/technology on which perform better than others? Amsoil ? Frantz ? Insane Diesel etc ?
Or, is just changing the oil and filter every 4k to 5k miles, and change the fuel filter every 10k miles the best way ?
If the truck has the DCR conversion installed and emissions deleted are these bypass oil filters a waste of money ?
Old Apr 30, 2026 | 08:38 AM
  #160
Overkill2's Avatar
Overkill2
He installed the Insane Diesel bypass... I had the Filtration Solutions FS2500 bypass on mine but the company got goofy and screwed me on two spin on filters (for their spin on conversion kit)... so I am going to a Dieselcraft OC25 centrifuge bypass filter... it will be a custom install since my truck is stock and there's no room under the hood, but there is a user on here who recently posted his OC25 install on his deleted truck where the EGR cooler used to be on top of the engine.
The truck in that video was stock. He used Insane Diesel's fuel additive and Motorcraft PM22 IIRC, and overdosed the additives. His CP4 came out in like new condition which IMO, speaks to the regular use of fuel additives which add lubricity and IMO, is a fuel cleaner as well.
I'm on my phone now and cannot see what year your truck is if you have a signature. If you use a oil bypass, theres no need to go 4k to 5k miles on oil. Even without a bypass, I don't believe it's necessary if you driving the truck a lot but if the truck sits, no matter the mileage, change out the oil and filter yearly..
But I'm not telling anyone when to change their oil... opinions and comfort levels differ on this just like they do with fuel additives.
If the truck is deleted and the DCR conversion is done, the oil bypass is up to you.... sure it will get some soot out but not all because soot gets down to the sub micron size... but what the bypass will do is get wear particles out of the oil to a level where the full flow oil filters cannot... there's a reason Derek's, the owner, engine went that many miles and I believe the Insane Diesel bypass helped, along with good maintenance and smart driving habits... but opinions on this will vary.
As to a DCR, I would still run my additives, for added cetane as well as fuel cleaner, if my truck ever needed one. I'm only going on 153k miles, so time will tell. I use additives every tank... opinions vary on fuel additives as well.
Old Apr 30, 2026 | 09:48 AM
  #161
Painted Horse's Avatar
Painted Horse
He said most of his oil changes were at 15,000 miles. His longest was 27,000, miles. And I'm sure his bypass filter was part of the reason he was able to achieve that mileage.
I've been sending oil samples off each oil change and have pushed my oil changes up to 10,000 miles. My oil samples are showing the oil is doing OK at 10,000 miles and I could go farther. I'm not willing to go farther,
I think you need to balance to Pro's vs the cost. The oil samples have allowed me to skip every other change. ( 10k vd 5k changes) That saves $130 per oil change and the oil sample was costing me $30, ( I think they have gone up to $40) So I'm $70-$80 per oil change ahead. The bypass filter kit is $650 plus install and filters are double the cost. I'm not sure for me, I can save enough to justify the cost.
At my age, I don't have a million miles left. But I would like my truck to go at least 300,000 maybe 400,000 miles. Each owner needs to make a similar decision.
Myself, I really think I will spend more money on front end parts, brakes, shocks, and electronics, than I will on engine repairs to get to 400,000 miles
Old Apr 30, 2026 | 10:28 AM
  #162
scraprat's Avatar
scraprat
Top Answer: 5
I try to figure the cost on return to ownership longevity of vehicles especially now with the ridiculous cost to buy in on a truck that depreciates the moment it drives off the lot. Each of us have a comfort level on top of all the pro/ cons.
My '16' 6.7 only has 84,000+/- miles, of those 45,000+/- have been pulling the 16k+ 5th wheel in the west. I like to think it gets a good work out to clean the engine some. I'll use Hot Shot EDT 1-2 oz every fill up. Use Rotella T6 every 7,000 miles (when truck shows change is needed). Changed the CP4 out to the DCR roughly 2 years ago when replacing the turbo for the occasional over boost condition. Truck seems to run like a charm climbing mountain grades holding speed with slow speed increase if I lock out OD before the base of the mountain grade. I don't see trading or replacing it unless something unforseen happens.
Now my '21' 7.3 Godzilla has 256,000+ miles on it and figure by end of year be near 300,000 miles. If it stays running like it does now with no oil consumption, oil samples sent into Blackstone come back excellent. I'll decide if it will keep racking up miles or drop another engine in it. I really want to see what it will go to but might be an inconvenience if something happens while traveling for work. Leaning towards keep going.
You notice in that video it's all about maintenance and changing parts as needed for longevity. It did appear he needed a seat in the truck though.
Old Apr 30, 2026 | 10:40 AM
  #163
Overkill2's Avatar
Overkill2
Yeah I forgot about that but sounded familiar with the 27k mile oil change. He probably felt confident with not only running with the ID bypass, but with running loaded and completing regens as well as the loaded weight and high EGT4 temps passively burning off the soot in the DPF, and not worrying about excess fuel in his engine oil at that high mileage...
Great points about each owner finding a routine, that they are comfortable with and financially as well, and just do what makes them feel good and what they want to do...
Old Apr 30, 2026 | 11:03 AM
  #164
Overkill2's Avatar
Overkill2
I have to watch that video again... I made a few comments on it and he answered me.
As to my transmission, when I'm local with lower speed limits, I lock out 6th gear. I also drive around in tow mode because I like the way she downshifts coming down hills to a stop sign and it keeps the RPMs up when driving also. We have V8s that like higher revs, not like the Cummins boys where they can lug all day at the lower RPMs.
Ive dropped the fluid in my trans 4 times already and have used LubeGard in my trans this last drop and believe the first time I R&R- ed the fluid... trans filter changed first time and this last time I believe...
Old habits die hard as my 96 F250 was a plow truck that pushed a lot of snow and those E4ODs were known to not Last, so I added stuff to it along with about 2 cases of ATF to make it last to 91k miles... anyways, that last fluid drop was at 50k miles IIRC and came back looking good from Blackstone Labs report from the sample I sent in.
Lots of in and out of that seat in 900k miles of hauling campers around the country...
Old Apr 30, 2026 | 12:50 PM
  #165
FishOnOne's Avatar
FishOnOne
So hot shot drivers don't have as many cold starts/1000 miles like the most of us which is when most of the engine wear occurs, so being able to reach 900k+ miles is not surprising and being able to go on longer oil change intervals is also not surprising since most of his regens were occurring at highway speeds which these diesel emission systems prefers. Having said that, I'm at 330k miles with a mix of city/hwy daily driving with all original engine components including water pumps and I prefer to change my oil at 5k-6k intervals using mostly Motorcraft oil filtes. I I only use Motorcraft fuel filters changing them out between 15k-20k miles and purging air out after filter changes ~10 cycles. I change my transmission fluid every 80k miles and change the filter every other drain. Air filters again I use only Motorcraft and change them once a year. Still have original CP4 pump and really started using fuel additives on a regular basis in the last ~2years and stick to high volume fuel stations with my favorites are Shell and Exxon/Mobil Diesel Efficient fuel.
My $0.02
