New engine
Old Sep 8, 2022 | 09:39 PM
  #31
440 sixpack's Avatar
440 sixpack
Don't know anything about that, may not be as bad as Ethelyn glycol on bearings. or how messy it is, I hate the feel and smell of antifreeze , when you smell it it's never a good thing.
If you'd never done it before you'd be amazed how much oil and gunk you drain with the water after a rebuild. it's never pretty, I doubt it really hurts much but I like it gone.
Old Sep 8, 2022 | 09:46 PM
  #32
thatsrealnice's Avatar
thatsrealnice
This stuff isn't as sticky. but it is oily. I suppose it too late now. Thanks for the info.
Old Sep 9, 2022 | 11:02 AM
  #33
mark a.'s Avatar
mark a.
Originally Posted by thatsrealnice
Just wondering, because I have already filled the radiator and block with Evans Waterless Coolant.
There is nothing wrong with using that stuff. It's a good idea to always psi check the system first. To avoid air locks I leave the thermostat and it's housing off when filling it.
Old Sep 9, 2022 | 02:24 PM
  #34
5851a's Avatar
5851a
Just pull hose off of the intake heater hose port when filling, the port is behind the thermostat and highest point on block. Lots of good advice on a long post. Having carb pre adjusted on another running engine and timing spot on ahead of time with an oil pump prelube. Never had much trouble on fire up.
Old Sep 9, 2022 | 04:52 PM
  #35
440 sixpack
Always drill a 1/8" hole in the thermostat plate and you'll never have air problems.
maxtor
Feb 8, 2017 09:24 PM
unibody62
Oct 21, 2016 08:07 AM
murdocksvillian
Apr 11, 2006 08:11 PM
rbachmann
1978 - 1996 Big Bronco
Nov 8, 2004 03:41 PM
2rockyou
Nov 29, 2002 08:08 AM
