Engine building checklist
Old Feb 5, 2017 | 12:15 PM
maxtor's Avatar
maxtor
There has been some discussion about following a engine building checklist. Even if you have built hundreds of engines, you can always get distracted and forget something. When I built engines, I made sure I was the only one around. Even at that, we can forget to do something. It only takes one error to make your day a bad one.
Old Feb 6, 2017 | 09:34 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Care to contribute?
Old Feb 6, 2017 | 01:19 PM
maxtor's Avatar
maxtor
Originally Posted by Krewat
Care to contribute?
I'll give it some thought. It would have to be generic and simple so anyone with minimum experience could follow along. When I build an engine, I blue print it, which would not be needed for the beginner or for someone who just wants a beater. Basic simple form with not torque specs. or detailing. Every engine I build is for racing, and require block preparation, where some steps would not be needed for the general public. A form to build after all machine work is completed and engine is ready for assembly. Cam bearings, freeze plugs, rings fitted, etc. etc. all done by a shop. Most people do not think about checking the clearance on the lifter bores, but to me it's a must. If the form is to complicated, the beginners will get lost. If it is to general, the beginners could miss a needed operation. Maybe that is why it is hard to find a beginners engine building checklist.
Old Feb 7, 2017 | 11:50 AM
maxtor's Avatar
maxtor
Ok;
Over the years I have been able to help many people build their FE's , so now that I am getting close to the end of my life, I might as well do something to help others with their projects.
I will start on it soon.
Old Feb 7, 2017 | 12:48 PM
krewat's Avatar
krewat
Hey man, thanks, it will be greatly appreciated!
Old Feb 8, 2017 | 09:24 PM
maxtor's Avatar
maxtor
Looks like a checklist has been created before. Click on the below.
https://emp.byui.edu/spratlingt/auto...vised%2012.pdf
77_f250_custom
16
Mar 2, 2015 01:58 PM
v8xploder
Dec 25, 2006 06:49 PM
58shortbed
Oct 17, 2004 03:32 PM
hazardousdrew
Dec 12, 2003 09:24 PM
MustangGT221
34
Sep 2, 2003 02:56 PM
