New engine
With that being said, the truck currently has a 400 that is unrepairable (cracked block) So I made the decision to search for a 460. I found a 514 and purchased it along with the hughes transmission and other items. I feel confident with installing the engine and already have purchased engine mounts, a larger radiator, a bigger fan, etc. My issue/concern is this, getting it started and cam broke in without wiping a lobe/lobes. It has a flat tappet cam, and I spent (at least to me) some coin on this setup. I have been trying everything under the sun trying to find someone who has an engine dyno to break it in correctly, but I have either come across "we don't have anything for BBF's or "we only deal with engines we have built", which I completely understand for liability reasons. Kaase actually referred me to a shop that isn't far from me that has great reviews and actually said they could help, but since the initial conversation.....communication has been cold. I am willing to wait as I realize shops are behind and it's the racing season...just want to know I am on the books
I am thinking about trying my hand at it. Concerns: based off the paperwork I have, the engine was built and assembled in 2012. Is there anything I should do or be concerned about outside of pre-oiling before the initial start up? The engine has never been fired and has sat in a shop since the owner got sick. I have a ton of paperwork on the engine.
Things I have come up with are:
- Needs to immediately start
- Needs to be ran 2k-2500 rpm for around 15 minutes and then fluctuate the rpm for the last 5 minutes.
- check oil pressure throughout, temp, amps etc
- use oil with ZDDP in it
- Check for leaks
- Have multiple people to help (don't have)
- A thermal gun ran on each cylinder
Apologize for the long post, but appreciate the feedback
First thing, do you know what cam it has ? what is the lift and what is the pressure over the nose ? it may be that you have to put weaker springs in for the break in then change them back.
Standard procedure is 20-30 minutes at 2k . don't worry about the rest of it everyone thinks they have the perfect recipe.
Run a high zinc non synthetic oil with a break in additive. or better yet break in oil.
Set you timing as close as possible and pour a few tablespoons of gas in the carb.
Have your dial back light hooked up and ready to go, as soon as it's up to speed set your timing . always be monitoring heat with a gun and watching for leaks. check the oil for water.
If it's been sitting that long I'd run the oil pressure up with a drill.
Do the best you can and if you fail it was probably going to fail no matter what. I've lost 2 cams on break in and everything went perfect as far as procedure. I've had sloppy break ins with shut downs and hard starts and they're just fine. don't sweat it that much you only have so much control over it.
Quick question, when you say run the oil pressure up...what does that mean? Is this referring to the pre oil time meaning make sure all the rockers are really saturated? The oil I purchased is comp cam break in oil and then will be changing to Vavoline 20-50 ZR1 if the break in goes well
Are you sure it has a flat tappet camshaft? It seems odd that someone would go to the expense of buying a stroker rotating assembly, then use a flat tappet camshaft. If it has a flat tappet camshaft, you definitely need to do a flat tappet break-in before driving it. If it was me, I'd install a roller camshaft.
Yes, you need to pre-lube the engine. You can buy a pressurized luber, or buy a drill type pre-lube shaft, or make a pre-luber from an old distributor out of a 460, 429, 351M, or 400. You definitely need to make sure the engine fires immediately. To increase chances of immediate fire up, triple check that you've got the distributor installed correctly, and prefill the carburetor float bowls. Ensure you have a good PCV setup so you don't blow gaskets and seals before the rings seat. Have a fire extinguisher on hand, and be able to instantly disconnect or cut the negative battery cable. Have a vacuum gauge hooked up, and have a screwdriver to adjust the idle and idle mixture screws. Have the correct wrench for the distributor hold down bracket so you can adjust timing. Assuming you're doing all this with the engine installed in the truck, ensure your transmission and transfer case are topped off with fluid. If it's a new automatic transmission, make sure the transmission and converter are topped off with fluid. And even a manual transmission in neutral needs oil during camshaft break-in...the input shaft and gears are spinning.
The 410 I bought sat for 50 years after being rebuilt adit had never been started.
It appears that the only thing that happened from that sitting that long is it looks like its going to need new valve stem seals.
I also went with Valvoline VR1 20w50 full synthetic racing oil.
Lucas Oil 10063 Engine Break in Oil Additive - TB Zinc Plus, 16 Ounce
Do you have roller rockers ? do you know the compression ratio? you might be burning race fuel. my guess is the cam card got lost for a reason. I would measure the lift you don't want a drag strip engine in a 4x4.
If it were me this is what I would do. pull the valve covers and see that you have. if it's a flat tappet you have 2 choices, if you have stout springs and you probably do change them out for break in then swap them back.
Or the best option. hopefully knowing the compression I'd order a custom spec roller cam and change it now. have a better running engine with no drama and no surprises. it'll run you about a grand. well maybe a little more today it's been a year or so since I bought a roller cam and lifters. you would not regret it. keep in mind if the cam gets wiped the whole engine has to be gone through.
And again, I'd take that engine apart for inspection. Not just looking for rust, but I'd be identifying every part, checking bearing clearances, valve spring specs, valve to seat fit, etc. If everything checks out, it'll only cost you a little time and a few gaskets. If it doesn't check out, you'll be saving yourself from a possible catastrophe.
I would pull a valve cover and see what you have, you've read enough on it, it is either going to go great or not. The only cam failures I had were in high mileage engines that were due for a rebuild, however, other than my most recent build, I haven't done one in about 5-6 years prior to that.
You got this, now go do it!
I pulled the spark plugs and looked into the cylinders with a bore scope. I found dead bugs in one if them.
I was also able to see that it had 0.030" over domed pistons which meant 10.5:1 compression. The cylinder walls looked great.
I also checked the bearing clearance on one rod and one main bearing. Rods and mains were 0.010 under.
Then I rotated the crank until I found the 1U stamp that verified that it was a 428 crankshaft.
When it was in the truck and ready to start the spark plus were still out of the engine so I just cranked it over until I was satisfied that the oil had gone thru ever oil passage and into the lifters.
Started right up with no clatter at all and it runs great.
if you are still concerned, you can check out Cam-King | Cam Reseach ? Custom Ford Camshafts They will break in your lifters and cam on their machine for $60
Michael
