4 on the Tree
Old Mar 2, 2022 | 05:11 AM
User 71024's Avatar
User 71024
4 on the Tree
I know I'm slightly misguided here, but the Econoline Forum is a dead animal so I figured I'd get better coverage here. I added a '65 E-100 Pickup to my collection and am looking for a 4 speed column shifter. They used them in '63 and 64. Want to add a 4 speed w/OD to my new ride and keep it on the column. I've been contemplating using the 3 speed for 1-4, them fabricating a 1 speed floor shifter for reverse, but that would make it a one man truck. Unless I came up with a way to lock out the 4 speed while it's in reverse.
Old Mar 2, 2022 | 02:51 PM
FuzzFace2's Avatar
FuzzFace2
First I want to see this E-100 pick up.
Is this a van with the top rear cut off to make a pick up?
Second I want to see some kind of proof that Ford had a 4 on the tree in 63 and 64 as I did not know they ever were done on USA cars or trucks.
If they used them in 63 & 64 what were they used on, car or truck or both?
I seen a French POS that had a 4 on the tree but that is the only one I had ever seen from anyone.
Good luck on your quest
Dave ----
Old Mar 2, 2022 | 03:55 PM
john jamieson's Avatar
john jamieson
I tjink Number Dummy mentioned Ford having a 4 speed column on some cars. I think they may have been in the '50's. I always thought it would be a neat setup if you have the room for the linkages.
Old Mar 2, 2022 | 05:34 PM
g4g2g7's Avatar
g4g2g7
30 second google search found numberdummy’s info in posts #5 & #13 of this thread:
https://www.ford-trucks.com/forums/1...-the-tree.html
also found this article and video of 4 on the tree in a ‘61 galaxie.
https://bangshift.com/bangshift1320/...-linkage-ever/
Old Mar 2, 2022 | 06:11 PM
FuzzFace2's Avatar
FuzzFace2
Well what do you know this old dog learned a new trick
Dave ----
Old Mar 2, 2022 | 07:13 PM
53deere's Avatar
53deere
I would think finding any 4 speed column shifter parts will be next to impossible. I think your idea of using the 3 + rev for the four forward gears is the best solution. Maybe even use a cable to engage reverse instead of trying to route additional linkage.
Old Mar 2, 2022 | 07:37 PM
Becky_is_a_66's Avatar
Becky_is_a_66
Maybe a more detailed explanation of the tranny you expect to use would be helpful. I would assume, since you want to use the column shift the tranny would necessarily have external shift arms? Are you looking at a tranny where 4th gear is OD? How was reverse engaged on these rarities that had a 4 on the tree? Just trying to get a picture of exactly what you wish to mate together
Old Mar 2, 2022 | 07:45 PM
85e150's Avatar
85e150
I'm not sure what you think you will find in this forum, where there was never a 4 on the tree. And what more do you think there is to find?
https://www.ford-trucks.com/forums/1...m-4-speed.html
Old Mar 3, 2022 | 04:23 AM
Thunderkiss1965's Avatar
Thunderkiss1965
Over only ever seen one 4 on the tree in my career, but I did see one. It was in a sixties Econoline.. it was at the upholstery shop next door to me so I didn't get to drive it or look underneath,
Old Mar 10, 2022 | 03:40 PM
User 71024's Avatar
User 71024
I thought I might find a Ford guy... I have a '66 F-250, a '65 Falcon and a '65 E-100 pickup, didn't think it was much of a stretch to find someone with knowledge of a 4 spd shifter here. And Fuzzy, it is a factory E-100 pickup, they made them from 1961 to 1967 it's pretty much a falcon with a pickup body on it. Has a 170 and a 3 on the tree right now, you could get them with the 144-170-200 or a 240 and in '63 and '64 you could get a 4 on the tree.. For some reason I can't upload a picture today but google it you'll find quite a few of them. I've actually had a few leads on the column shifter, but haven't found one yet.
PS. I found the 4 speed, went down to Jacksonville and picked it up with a rebuilt 170 out of a '63 falcon. So I just need the shifter.
Old Mar 10, 2022 | 03:44 PM
User 71024's Avatar
User 71024
Dave ----
Fuzzy, I had a customers years ago with a Mercedes that had a 4 on the tree. Until I bought this, I didn't know they existed.
Old Mar 10, 2022 | 08:27 PM
SwampRattFord's Avatar
SwampRattFord
I drove a Mitsubishi on Okinawa in 1972 with a 4 on the tree, I don’t remember where reverse was. Used to trade cigarettes to use the little car.
1951flatheaddave
21
Jul 9, 2020 03:30 PM
BeauF0RD
17
Oct 23, 2017 06:10 PM
56 f100 long
Mar 16, 2016 02:39 PM
cbfomoco
Oct 22, 2005 03:09 PM
F250Rob
23
Nov 27, 2003 05:56 PM
