Please help a moron!!!!
Old Feb 26, 2022 | 06:01 PM
THE FISH BAIT's Avatar
THE FISH BAIT
Short of it is, I dropped a plenum bolt down the intake while positioning the plenum. Yall have any suggestions for retrieving it before I pull the head. Any advice, tips, or old shaman tricks would be greatly appreciated.
Thanks
Chad
Old Feb 26, 2022 | 06:40 PM
F0rdc0wb0y's Avatar
F0rdc0wb0y
Crud! My first thought would be to use a bore scope to try and locate it first. Then (if located) maybe come up with a plan for extraction.
I think a few months back there was another forum member who dropped a bolt down the intake. I don’t think the outcome was positive for him unfortunately.
Old Feb 26, 2022 | 07:22 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
What F0rdc0wb0y said... Off to find the thread now and will update my post when I do. There were a lot of good ideas for him to try.
Edit: https://www.ford-trucks.com/forums/1655586-bolt-dropped-down-the-plenum.html?highlight=Plenum
Old Feb 26, 2022 | 07:57 PM
RacinJasonWV's Avatar
RacinJasonWV
An actual plenum bolt? They’re fairly large. I’d think it would still be in the port side of the head somewhere. Did you finish installing the plenum? My first thought is to halt the installation and pull the plenum back off. If it’s already installed you may want to try searching with a bore scope. This is the one I bought a few years ago. Amazon DEPSTECH camera
As the others have mentioned, clineco lost a bolt down the plenum with very bad results.
Old Feb 26, 2022 | 09:32 PM
josht's Avatar
josht
I'm agreeing with @RacinJasonWV , given the size of the bolts, I would think that it is probably still in the intake port. Definitely want to find it before you move on. If you can locate it with a bore scope, might try magnet fishing. If the magnet won't work due to other iron around, maybe try a shop vac. What we'll do at work (not in an engine and a standard shop vac) is adapt the vac hose down to a small diameter clear tube and use that to suck up FOD (Foreign Object Debris) in hard to reach spots. I might would even try either of these methods while waiting on a camera in hopes the I might get lucky.
Old Feb 27, 2022 | 06:35 AM
FordTruckNoob's Avatar
FordTruckNoob
If you are using a shop vac, empty the shop vac first so you’re not digging through other crap to confirm you got the plenum bolt out. If you suck more than just the plenum bolt out of the head however…
Old Feb 27, 2022 | 07:25 AM
THE FISH BAIT
I’m going to call some of my amigos and try to find a bore scope, unfortunately I don’t have one. I’m pretty sure it went down the number 6 intake. It was a one in a million shot I had plenum in one hand and bolt in the other. The plenum wasn’t even close to the head yet, but when the bolt slipped out of my fingers it bounced off the plenum and into the head. I’m liking the shop vac idea I’ve got everything it will take to give it a try. Thanks for the advice.
Old Feb 27, 2022 | 09:48 AM
THE FISH BAIT
THANK THE GOOD LORD IN HEAVEN!!!!!! I got it!!!! A 60$ bore scope from harbor freight and a magnet got the job done. It was sitting right on top of the valve on #4 cylinder. Thanks again for the advice y’all!
Old Feb 27, 2022 | 10:19 AM
Sous's Avatar
Sous
FTE Emeritus
That is your 2022 "get out of jail free" card sir. Congratulations and good luck on the rest of your project.
Old Feb 27, 2022 | 11:40 AM
F0rdc0wb0y's Avatar
F0rdc0wb0y
Hell yeah!!!!!!
Old Feb 27, 2022 | 12:36 PM
RacinJasonWV
Great news!
blackk5250
Modular V8 (4.6L, 5.4L)
Dec 10, 2017 10:46 AM
andyman91
Jan 31, 2010 03:27 PM
MattV
17
Oct 10, 2007 01:59 PM
wellys
Sep 3, 2007 09:01 AM
a_Pink_Bunny
Jun 9, 2002 11:21 PM
