intake plenum removal
Old Sep 2, 2007 | 06:50 PM
wellys's Avatar
wellys
there is a bolt or what ever it is under the intake on a 302 in the middle holding it on i got the other 5 out in a 95 f150 on the left hand side underneath that i cannot get of can anyone provide info on this would be greatly appreciated
Old Sep 2, 2007 | 06:55 PM
Peter94's Avatar
Peter94
Are you talking about removing the upper plenum? I believe there is a torx drive bolt in the center on the left that you have to use an extension. Or mabye its just a regular. I'm not sure but I know I had to go at it from the top with an extension
Old Sep 2, 2007 | 08:11 PM
mrl390's Avatar
mrl390
It is a torx head bolt. I think ford threw that in there to screw with everyone. You will need an extention or two on your ratchet to get it out. Good luck and dont drop the bit!
Old Sep 2, 2007 | 09:38 PM
jroehl's Avatar
jroehl
Tape the bit into a socket. Should be a T40, IIRC.
Jason
Old Sep 2, 2007 | 10:36 PM
wellys's Avatar
wellys
Thanks every one
I had a good look in there and there aint much room I know a 1/4 drive wouldnt fit down thru the gap and it looked like a round headed stud in there, well thanks for all the help I will give it another shot tomorrow, I am going to try an put carburetters on the engine and fit it into a 72 mercury capri, is there anything I should know about this engine before i try the swap im hopeing the cars existing gearbox can be fitted to engine by using a mustang bell housing, any info greatly appreciated, thanks
Old Sep 3, 2007 | 08:45 AM
lostin90s's Avatar
lostin90s
Unless you have a high quality tork set that are small in Diameter .
Go get a cheap set of cordless driver bits . You need a T40 tape that bit into the right size socket and using a 1/4 x 6 or longer extenion you can get it.
Good luck the first time sucks replace pcv valve while in there.
Old Sep 3, 2007 | 09:01 AM
jroehl's Avatar
jroehl
My bad....yes, you need a Torx screwdriver bit, not a 3/8"-drive Torx bit, unless it's the one made for this case (the "bit" part is ~6" long). I tape the Torx bit into a 1/4"-drive 1/4" socket and put an extension on it.
Jason
shortwide
May 11, 2022 12:39 PM
steve340
May 29, 2016 07:53 PM
trucker01
16
May 10, 2014 09:23 PM
thomas5853
Nov 2, 2010 08:51 AM
1COOKIEMON
Sep 23, 2007 06:37 AM
