removing the intake need help
Old Jan 30, 2010 | 05:36 PM
andyman91's Avatar
andyman91
Hi i am removing the intake on my 5.0 i got the bolts in the front the side and one in the back and the one that grounds a wire. I was wondering if there are anymore bolts.
Old Jan 30, 2010 | 05:45 PM
BRay09's Avatar
BRay09
There should be a T30 torx bit in the left-middle of the intake. 6 bolts altogether.
Old Jan 30, 2010 | 06:25 PM
ri_truck_guy's Avatar
ri_truck_guy
There are actually two middle bolts....one you can see on the drivers side in the middle of the plenum, and the torx head bolt that's located in between the runners directly opposite the drivers side middle bolt. You can't see it unless you're looking directly down between the runners.
There's no good tool to get that middle torx head bolt. I ended up making a tool by welding a t30 tip to a long thin rod, then welded a cross piece at the top to make my own t-handle wrench. You need to make it at least ten inches long. I know it sounds like a lot, but it will save a lot of grief.
Old Jan 31, 2010 | 09:47 AM
BRay09's Avatar
BRay09
1/4 rachet with a 8" extension and the 1/4 drive torx will work...
Old Jan 31, 2010 | 09:54 AM
ri_truck_guy
I thought that...until I tried to find a 1/4 inch T30....I'm sure they are out there, but couldn't easily get ahold of one.
Old Jan 31, 2010 | 10:27 AM
Conanski's Avatar
Conanski
Torx bits can be purchased bare meaning without a socket head attached, tape that into a 1/4 drive 1/4" socket with the extension attached.
Old Jan 31, 2010 | 12:06 PM
andyman91's Avatar
andyman91
i just gave up didn't have the tool so cleaned the throttle body and put it back together it runs a lot better
Old Jan 31, 2010 | 12:35 PM
zxwut?'s Avatar
zxwut?
Wow. What a loss of motivation. Hopefully you don't give up so easily in everything you do lolz
Old Jan 31, 2010 | 01:47 PM
skyfox10's Avatar
skyfox10
Snap on makes a tool specifically for this application. it even has FT in the part number. i bought one when I had to take mine off.
Old Jan 31, 2010 | 02:19 PM
rainbowATF's Avatar
rainbowATF
I used a T40 on mine last summer. Other threads searched say it is a T45??
Old Jan 31, 2010 | 02:53 PM
97FRD1TN's Avatar
97FRD1TN
It's most definitely a T40.I just tore my upper and lower off 2 weeks ago,so the agony of that is still fresh in my head.
Old Jan 31, 2010 | 03:27 PM
ri_truck_guy
You are correct sir. I just checked my tool and it is indeed T40 (hold the comments ). Either way, I can't stress enough how easy and cheap it was to make my own t-handle, or how well it works.
ericford1984
Mar 23, 2026 04:23 AM
bryan_johnson
18
Mar 3, 2019 09:13 AM
banjopicker66
Mar 23, 2010 03:22 PM
111989F250
Jun 19, 2009 01:12 PM
91Bronc300
22
Apr 6, 2009 08:16 PM
