Sponsored by: Real Truck
Adding a keyless key pad
Old Sep 7, 2021 | 12:57 PM
dirtnap's Avatar
dirtnap
Hello everyone, new here. I just picked up a 2015 F250 XL regular cab. It's my daily driver for now but that may change and just be used around the farm etc. Anyway, I'm upgrading a few parts to make the truck more livable. One is a keypad outside for keyless entry. I got it from Tasca online. It's got the right frequency and it seems like I'm in program mode when I cycle the ignition 8 times but the key pad won't connect. Nothing when I push 7/8 9/0. Anyone have any idea why?
Thanks
Old Sep 7, 2021 | 01:20 PM
Just Strokin's Avatar
Just Strokin
when you cycle the key 8 times, do the doors lock and then unlock?
Old Sep 8, 2021 | 07:49 AM
dirtnap's Avatar
dirtnap
Yes they do
Old Sep 8, 2021 | 06:44 PM
Just Strokin
you are pushing 7/8 and 9/0 at the same time?
Old Sep 8, 2021 | 07:22 PM
dirtnap's Avatar
dirtnap
Yes. I watched a video where the guy said you need to do both keys as well. I'm not sure if I tried it without doing the keys. I can try that tomorrow. The small red light did light up when I pushed the 7/8 and 9/0 but the locks didn't unlock or lock.
Old Sep 8, 2021 | 08:04 PM
Just Strokin
read Type B programming.
File Type: pdf
Old Sep 9, 2021 | 08:15 PM
dirtnap's Avatar
dirtnap
Thank you, I will try that.
Old Sep 10, 2021 | 05:01 PM
dirtnap's Avatar
dirtnap
It still won't work. The problem I'm having is when I get to step 23, one of the keys I have will cycle the locks and the other sounds the horn instead. I've tried the keypad in multiple scenarios, trying it without activating the keys, activating one key. It was attached to the vehicle, I took it off and tried it. Still nothing. Is there a way to do it through Forscan?
Thanks
Old Sep 10, 2021 | 08:43 PM
Just Strokin
You have all the methods in that pdf....2017 and newer require using the Ford IDS. Not sure FORScan will do it. Go to the FORSan website and search or ask in the forums.
www.forscan.org
Old Sep 10, 2021 | 08:44 PM
Just Strokin
You only need one key to do the 8 key turns. You are leaving the key "on" on the 8th turn?
Old Sep 10, 2021 | 09:39 PM
dirtnap's Avatar
dirtnap
yup, leaving it in. I'm gonna try pulling the battery out of the key that sounded the horn and see if that works
Old Sep 12, 2021 | 06:53 AM
dirtnap's Avatar
dirtnap
Well that didn't work either. Starting to think it's a bad unit.
Old Sep 12, 2021 | 07:01 AM
dirtnap's Avatar
dirtnap
Does anyone know if Forscan will program this?
mxer0022
Aug 28, 2022 06:01 PM
fordman67
Aug 14, 2015 09:56 PM
nastyss
Sep 24, 2004 01:35 PM
oggjay
Sep 1, 2004 11:01 PM
will-work -for-mud
1997 - 2003 F150
Jan 29, 2004 12:46 AM
