Keyless entry
You can program the key fob by yourself.
Put the key in the ignition and turn it from off to run 8 times in 10 seconds. The door locks will cycle. Then press any button on both key fobs. The locks should cycle again and you're done.
Our '01 SuperCrew came with Keyless entry. We had a FORD keyless/security/remote start entry installed. We kept the 2 originals, so we have extras.
(Figured, that I might drop one someday, and crack/break it, and need the case)
Well I bought a new keypad off ebay and tried to program it. It wouldn't work on mine because it for '98 and up vehicles. Being that mine is a '97 model... I was kinda frustrated. It's been so long since I have seen the one that came with my truck that I don't remember if it had the words on the buttons or if it had the little picturs of the lock open and lock closed. Does anyone know which it is? I am thinking it is the keypad that has the words on it.
-Landon
-Landon
My F150 - 1997 key transmitter has words, no pictures.
Here are the numbers off the back:
FCC ID: GQ43VT4T
DOC: 1470 K763
TRW Inc 3165189
>Dan
FCC ID: GQ43VT4T
DOC: 1470 K763
TRW Inc 3165189
>Dan
