Great news, I found two Stock 22s that have been produced. See spreadsheet. One built yesterday and one today. Both 7.3 XLs and going to Koons of Annapolis.
Not sure if they will be held for clear to sell, or if that is not necessary since these XLs are basically identical to the 21s.
An interesting note is that the window sticker is not available for either of these trucks on the Mach E tracker. Since they are stock orders they can't be tracked on the Ford tracker either.
I'll post the VINs since these are Stock orders and someone else may want to search for them.
Very cool! Thanks for posting this Phoenixfla!
Well... seeing these early built trucks completely blows away my theory of sequential VIN#'s!! 😆 lol!
(mine is 06066)
(mine is 06066)
Looks like some stock and retail 2022s were built on 7/10 & 7/11. They may not ship till the plant starts back up and they get 5 days of no issues.
I added a new column for ETA Start which comes from the data pull and is the start of the ETA window. Those columns should update from 1990 once they start shipping.
Still no additional window stickers other than 16superduties. Even the built trucks don't display window stickers. Very odd.
Trim level column is now populating. I have to manually add the sent to plant date once window stickers start appearing. That's the only manual update column, but the best indication that the truck will be built very soon. (Usually in 7 days).
Is there a way to add a column stating if (or when) the window sticker becomes available? That way we could track the time from when the window sticker becomes available and the truck is produced.
I've tried, but nothing in the data stream indicates when a window sticker is available or when it's sent to plant. They are the same day I believe, and when I look at their normal cycle, they are produced as little as 5 days after window sticker released, and as many as 10 days. (Assuming no shutdowns like this week.
I think we will get a bunch all at once, so hopefully we will see posts here indicating they are being issued.
In the raw data of the Mach E viewer, there's a string of text following "window sticker". Any idea what that means? I would think that if it's populated, it means there is one. Which would mean that Ford has window stickers already prepared that they haven't released yet.
I played around with that the other day. For the couple of 22s that have a window sticker, they are only available from ford.com, not on the Mach E tracker.
I was wondering why because they both draw from the same Ford website. When I looked further, the window sticker can be retrieved by VIN or Token (a string of letters and numbers). The 22s that were visible were only retrieved when the token was used and could not be retrieved by vin.
I compared that known good token to the data in the feed to see if it was the same, but the token string is much longer.
Therefore, I haven't found a way to use that information. It must be used for something though.
Not sure if you are interested for tracking purposes, but my dealer is showing a "Dealer Ordered" 2022 F-350 XLT 1FTRF3BT5NEC30819
Sands Ford of Red Hill on the Build and Price Ford Site.
Today someone brought to my attention the possibility that a bad-intentioned third party seeing one of the incoming trucks and contact the dealer to try to buy it out from under the person who ordered. So that we are not connecting the tracked trucks to a certain dealer, and in an abundance of caution, I have removed the Dealer Name and City.
