Old Feb 23, 2021 | 10:41 AM
R&S20's Avatar
R&S20
Set motor and tranny(can i say that) on frame to check fit sept 11th Had a hold up on progress due to hurricane Laura
Also check fit of exhaust system
Old Feb 23, 2021 | 10:48 AM
R&S20's Avatar
R&S20
This was nov 11th Had another hold up, hauling equipment back from helping family with Laura damages blew head gasket and piston ate a piston ring on one of my 7.3l psd so had to rebuild that, got lots of good info and help from this forum with that project
installed new gas tank
Old Feb 23, 2021 | 11:09 AM
R&S20's Avatar
R&S20
Dec 18th started working on cab
Dec 20 started on repairing doors
More on driver door
Old Feb 23, 2021 | 11:48 AM
Flecker's Avatar
Flecker
Love it! Gonna be an awesome build man!
Old Feb 23, 2021 | 01:54 PM
R&S20's Avatar
R&S20
Had to charge battery, on to more posting of progress
Cab in blasting tent
See i told ya
Old Feb 23, 2021 | 02:02 PM
R&S20's Avatar
R&S20
Previous was from dec 22nd Working on stripping cab
Now cab is stripped These are dec 27th
Old Feb 23, 2021 | 02:06 PM
R&S20's Avatar
R&S20
Cleaned floor Found 4 pin holes in floor board Probably due to when i the truck i stripped floor mat out and osphed floor
Old Feb 23, 2021 | 02:24 PM
R&S20's Avatar
R&S20
A little more info on the truck
when i bought it, it came stock with a 302, 3 speed on the tree.
the clutch was rusted to the flywheel.
a little work on the points and she was running. My brother in law drug me around the yard while i was playing with the clutch it finally broke free. After that it was off to the races.
i never changed the clutch or worked on brakes everything work good.
i am going back with a slightly modified 302 and a m5r2 transmisson for the overdrive
the transmission was rebuilt by a very good local shop several years ago. The transmission only has 500 miles at most on it, then the truck was traded in. I bought the truck for 200.00 sold bed,cab,motor, and other parts. I came out good, i bought the truck for the tranny.
i have changed all the brake and fuel lines now.
with kits available online.
i just got a parts truck so i will converting the truck to power steering and power brakes. By the way parts was free had to go pickup, only went about 65 miles to get it so if radiator is good im ahead without the other parts.
Old Feb 23, 2021 | 02:31 PM
R&S20's Avatar
R&S20
Cleaning firewall Jan 1st
Old Feb 23, 2021 | 02:40 PM
R&S20's Avatar
R&S20
New rear cab corners, the worst spot on truck for rust Jan. 6th
Old Feb 23, 2021 | 02:52 PM
R&S20's Avatar
R&S20
Driver side was the worst
Cleaned and treated
After market sheet metal will make you work for it
Installed
Finally primered jan 7th
Old Feb 23, 2021 | 02:59 PM
R&S20's Avatar
R&S20
Truck color test
I think i like it I let my kids pick it out,not a good job. Paint gun decided to not work right. Makes it a good choice to paint bottom of cab to see.
Old Feb 23, 2021 | 03:08 PM
  #28
R&S20's Avatar
R&S20
This how she sits for now. My sons truck got wrecked so i am rebuilding it now, if the weather straightens up it is ready for paint. Jan 10th
On a side note bought this 1993 f250, 351w and auto for 200.00. Needs fuel pumps. If i knew i was gonna get the 351w i would have built it up for 85.50 instead of the 302.
Old Feb 24, 2021 | 07:12 AM
  #29
Meridian_Mike's Avatar
Meridian_Mike
Good work!
I am enjoying seeing your progress! Great pictures too!
Keep up the good work.
Old Apr 12, 2021 | 07:44 PM
  #30
R&S20's Avatar
R&S20
We have managed to get a little more work done on her
Took motor back off of frame for rebuilding and painting
More painting of motor parts
Motor mostly assembled
