SEIC High Idle
Old Jan 12, 2021 | 06:29 PM
mooreswm's Avatar
mooreswm
SEIC High Idle
I know this has been talked about before but i would like your input.
I have a 2015 F350,6.7 and I followed the steps in earlier posts as well as the ford service bulletin on how to install it, can't get it to work. I installed the 50K pot the power is a switched circuit from the battery still not working. I work on commercial radios as well other electronics so I'm not new to working with electronics So does anyone else had the problem or other suggestions I would appreciate any and all input.
Thanks Steve
Old Jan 12, 2021 | 06:48 PM
ford390gashog's Avatar
ford390gashog
Is the parking brake in the circuit or did you opt to bypass with a relay?
Old Jan 12, 2021 | 07:04 PM
Just Strokin's Avatar
Just Strokin
check this chart to see if you have met the enabler rquirements.
Old Jan 12, 2021 | 08:34 PM
mooreswm's Avatar
mooreswm
Yes I checked all of them I got that list from ford service bulletin Thanks
Old Jan 12, 2021 | 08:36 PM
mooreswm's Avatar
mooreswm
I did not bypass it checked it with and without
Old Jan 15, 2021 | 07:55 AM
Trash Hauler's Avatar
Trash Hauler
Here is a link to my install. There is a basic schematic in the post. I suspect you just have something connected incorrectly.https://www.ford-trucks.com/forums/1...ing-brake.html
Bob
Old Jan 15, 2021 | 11:58 AM
stryder's Avatar
stryder
Not sure if the harness is the same as a 2020, but double check you have the correct wire in the upfitter harness. On my 2020, there are 2 wires that are the same color. I didn't realize that why I wired mine and chose the wrong one the 1st time. Finally figured it out when I followed the sheet and went by pin number. Switched wires and it worked perfectly.
Iaff113
Mar 3, 2014 11:20 AM
davinci69
Sep 13, 2012 10:53 PM
Green_Monster
Mar 1, 2008 08:52 PM
DISLFVR
Feb 18, 2007 11:52 AM
Steve_250
Jan 10, 2006 09:04 PM
