High idle
Old Mar 2, 2014 | 12:10 PM
Iaff113's Avatar
Iaff113
High idle
So I just started messing with my high idle. For anyone else that has this. If you drive then stop and park with the truck at idle and turn it on, will it come on right away or does it wait?
Old Mar 2, 2014 | 12:13 PM
npccpartsman's Avatar
npccpartsman
It should come on fairly fast if you aren't touching the foot brake.
Old Mar 2, 2014 | 12:58 PM
holdtyte's Avatar
holdtyte
On my high idle mod the Emergency brake also needs to be on. The high idle ramps up after 30 seconds or so.
Old Mar 2, 2014 | 01:00 PM
holdtyte's Avatar
holdtyte
With my high idle mod the emergency brake needs to be on. The high idle ramps up after 30 seconds or so.
Old Mar 2, 2014 | 01:42 PM
mhoefer's Avatar
mhoefer
Which color wire are you using, the charge protect or the high idle for PTO? They do reacts slightly differently. I am using charge protect, as long as it's in park, up fitter 4 is on, and e-brake is on, then it idles up in a few seconds, it never takes as long as 30 seconds. I am thinking PTO idles has a longer delay, but again, foot off the brake, in park, e-brake has to be on for it to work right. If this isn't working, you have the wrong wire in the up fitter bundle, may need to try some testing, make sure you shrink tube and seal off all bare wires when you are done, a bare wire to ground can cause you lots of problems later on.
Old Mar 2, 2014 | 01:45 PM
Iaff113's Avatar
Iaff113
I use the purple wire with green strip which I think is not the pto wire. It seems off and on maybe it's because the parking break I didn't think it had to be on. Just seems after a drive I can park flip aux 4 and nothing. I'll do some more testing
Old Mar 2, 2014 | 01:53 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
PTO gradually ramps up. The BCP is usually instant, although for whatever reason their can be a few second delay flipping the switch and when it idles up.
Either way, both need the E-Brake set to initiate the high idle.
Josh
Old Mar 2, 2014 | 04:35 PM
defyrftr's Avatar
defyrftr
There must be a difference between the years because my 03 doesn't need the e-brake engaged.
Old Mar 2, 2014 | 04:54 PM
Bullitt390's Avatar
Bullitt390
Or your e-brake switch is broken...
Josh
Old Mar 2, 2014 | 09:20 PM
lupuseven's Avatar
lupuseven
My Early '04 doesn't need the e-brake engaged either
******** charset="UTF-8" src="chrome://hdv/content/hdv.js" type="application/javascript">*********>
Old Mar 2, 2014 | 09:55 PM
avfrog's Avatar
avfrog
Sounds about right to me. I wired mine to get 12v from the running lamp switch. I didn't want any toggle switches in the dash or but the upfitter switches.
But ya I get about 0-10 seconds of delay.
Old Mar 3, 2014 | 11:20 AM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Yes, the 03-04 has different set up for high idle, than the 05-07.
Curt's05
Nov 24, 2013 08:03 PM
Acftmaintainer
Sep 9, 2010 06:39 PM
blong2107
May 20, 2009 10:36 PM
lowcan
Dec 8, 2008 09:56 PM
nut1605
Dec 5, 2006 02:09 PM
