PTO high idle
Old Aug 28, 2012 | 04:51 PM
davinci69's Avatar
davinci69
PTO high idle
My PTO high idle has quit working, all fuses, switches wiring etc seem to be in good repair.... stumped (wired to uplifter switch #3.
Any ideas?
Old Aug 28, 2012 | 04:57 PM
bpounds's Avatar
bpounds
If it used to work, but now it has quit, then I would take a look at the switches for the conditions required for high idle, which are the E-brake must be on, and the service brake must be off. Also must be in Park (or neutral if a manual tranny). There are switches for each of those conditions.
Old Aug 28, 2012 | 08:25 PM
davinci69's Avatar
davinci69
It is a standard, park brake sewitch working (light comes on, tranny in neutral but the spedo does not work....
Old Aug 28, 2012 | 09:16 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Isn't there a logic module for hi idle functions? That may have crapped out.
Old Aug 29, 2012 | 09:07 AM
bpounds's Avatar
bpounds
Tell more about the speedo not working. You mean it doesn't work when you drive down the street?
One of the conditions for high idle is that the truck is stationary. If the speedo isn't working, because of a bad VSS for example, it is logical to assume that the PCM would not allow high idle. The VSS system is how the PCM knows the truck is or isn't stationary. There should be a DTC for something like that.
I don't think there is any separate high idle module. It is a PCM controlled function.
Old Sep 13, 2012 | 05:33 PM
davinci69's Avatar
davinci69
I picked up a scanner today, will scan for codes and yes the speedo does not work going down the street. I will let you know the results.
Old Sep 13, 2012 | 10:53 PM
william_04_x's Avatar
william_04_x
Did the high idle stop working when the speedo died? Do any of the other dash functions work? Are you sure the 12+ signal is making it through your switch?
Markus Luukko
Jan 9, 2019 07:22 AM
Iaff113
Mar 3, 2014 11:20 AM
Serapis
Sep 9, 2010 11:22 PM
jaybread
6.4L Power Stroke Diesel
Mar 21, 2009 04:35 AM
DISLFVR
Feb 18, 2007 11:52 AM
