New design cp4????
I've done the experiments they list on their site and combined 1/3 water and 2/3 K100D. It's amazing to watch as the water literally begins to combine with the K100 as it totally disappears.
I rolled up a paper towel, stuck it in the jar, let the mixture suck all the up the paper which I lit as a wick, it burned with no to very little smoke, and I could hear the water popping off as it was turned into steam by the flame. It just kept burning and never stopped.
I've talked to a few diesel mechanics here who love it. Met a guy who owns a newer deleted Chevy dually who runs it. I get your cautiousness towards it. No problem.
I have a container of diesel from my DFCM filter drains to change the filter. I have plans for it. I want to make some videos. Maybe I'll have to post them to my new thread involving that old diesel, some water and K100D. Maybe even some water detecting paste. We'll see...
Take it easy and good luck with your truck.
What I am saying is the water needs to be separated from the fuel, not emulsified to go through.
I would like to see a demonstration by an independent test lab run some water/fuel mix with this K100D through a CP4 pump at 35000 psi and see what happens.
From this link.
https://allinthewristauto.com/diesel...el-hard-start/
Another reason I run it; get rid of the moisture, get rid of the potential of "bugs."
K100D breaks the bigger chunks or pieces of water down to the molecular level. It combines with it chemically, totally encapsulating it in a burnable compound to be sent to the combustion chamber to burned off harmlessly. It is in permanent solution.
There is a spec for moisture in fuel and an acceptable amount. I remember reading that the very process of getting the sulfur out of fuel makes the fuel more susceptible to moisture absorption.
What happens if you get a tank of contaminated fuel and it over powers the water separator because there's too much moisture for it to handle? How do you know that it won't happen and the water separator can deal with it?
I'd love to send two samples of fuel from where I usually buy mine to a lab; one without K100D and one with. But it ain't cheap. If I could afford it, I would.
This does come down to a emulsifier versus a demulsifier. So I see your argument. But with the fuel constantly being agitated in a moving vehicle's tank, I don't see how it's guaranteed that my factory water separator will get every last bit of water if I was to get a tankful of bad diesel.
I have a 16. There has to be a reason why Ford changed up their fuel system to a bigger primary filter and water separator from my gen truck.
If someone will be so kind as to do that, I would be impressed.
PS: I don’t care if the water burns or not; but what condition the fuel system is in after the fact.
If this stuff was bad, I'd doubt they'd still be in business. Or selling the product. I just don't agree with the use of a demulsifier as opposed to what I use. I'll see at 125k miles when my truck gets there. Like I said, If I'm wrong, I'll be the first to admit it.
I haven't and don't drain my DFCM every other tank or month. I have confidence in K100D. If I had water, I wouldn't know it.
I have old diesel sitting in an container in my unheated garage that was drained the times when I changed the DFCM filter. I am saving it to possibly make a video or two. Stay tuned.
I know what you're saying. I never said you said it was a bad product. I'm just stating the reasons why I use it. No worries here.
My dad drove truck too. Got a soft spot for big truck drivers.
But with modern diesel fuel, I err on the side of caution. When I first bought my truck, my first diesel, I researched the fuel itself. The way I look at it is I'm not willing to throw the dice when it comes to my $69k truck. Opinions will vary, that I get. I look at it from the worst case scenario. On their site, they list ULSD as a 90 day fuel. So if I got an older batch of fuel, K100 would help to bring it back up to snuff. I don't believe in luck. But I do believe in Mr. Murphy. That's why I use it, because basically, I don't trust today's ULSD fuel. The same reason I conceal carry... just in case.
The website, dieselsite.com and it's owner, Bob Riley had a similar experience with his truck. That's why he came up with their water separator filter system for the 6.7 trucks. I'm going off of memory here for this so I'm sorry if I'm wrong. Here's a link to the page for more info.
https://www.dieselsite.com/dieselsit...separator.aspx
There has to be a reason that Ford changed the design of their primary filter and water separator and made it bigger. I'm thinking it was for a bigger capacity for water separation to prevent what happened with the 11 to 16 trucks like mine.
So instead of going underneath the truck to periodically drain to check for water, I'd prefer to use K100D to take care of the water issue and not depend on the factory solution to separate it from the fuel. I'll also get the other benefits of my additive as well. But that's just me.
It's always puzzled me to how folks say to buy from high traffic fuel stations and I understand the point. But how does that guarantee that there won't be a little, some or a lot of water in that fuel without testing it? You can't stick your head inside the tank or look at the bottom of the tank to check.
I'm from the same camp that bobcat is with that you can be sure there is some moisture in that fuel when you fill the tank. My point was not so much about what I use, or that it is the best but rather why I use it and how I feel like it benefits me. That's all.
With these new, high pressure common rail fuel systems, their ability to deal with some moisture is non-existent. They simply cannot. The engines of the old days with their lower pressures were much more tolerant of moisture and other issues.
Also saw a video on youtube where the guy said you are supposed to cycle the key multiple times (like when changing the separator). I have never done that but then again I only drain a couple ounces. Since the water is on the bottom anyway it's stupid to drain the whole separator
Since I don't have the exact facts or numbers on how these HPFP failures happened and how many, I'd rather play it safe with additive. My additive is designed to take water out of the equation. And it adds more lubricity to the fuel at the same time.
Maybe I am lucky. Or maybe my additive works. Time will tell. Meanwhile, I'm going to keep doing what I do.
This is just chemistry at work. I'm not a chemist so I really can't explain how it does it and how the water stays in permanent solution when the K100D reacts with it, breaks it down to the molecular level and encapsulates it with a burnable compound to not only keep the fuel system safe from the water, but to use it to harmlessly burn off in the combustion chamber for a cleaning effect.
Thanks!
