New injectors
Old Nov 21, 2020 | 09:37 AM
F350 1990's Avatar
F350 1990
For those on their last legs w/injectors -- a last ditch effort using friction modifiers, (largely silicon based), stiction elimination additives (e.g. Hot Shots, Arch Oil, Rev X, etc) may buy you further time -- the treatment is not guaranteed but can be effective in quite a few cases. Third party testing, using ASTM D4828 testing standards seems to bear out most of these vendor's claims.
Always apply initial dose during a fresh oil change, then augment over time.
Old Nov 21, 2020 | 09:38 AM
william_04_x's Avatar
william_04_x
The 7.3s don't fit well
My mind was spinning when he told me that. For a split second I knew absolutely nothing. I was so confused. Fight or flight kicked in, and I just said, "BYE!".
Old Nov 21, 2020 | 09:40 AM
bismic's Avatar
bismic
LOL, that's a new one!
Old Nov 21, 2020 | 09:47 AM
william_04_x
I would have probably been better off chatting with Andrea!
Old Nov 21, 2020 | 09:53 AM
bismic's Avatar
bismic
No doubt!!!
Old Nov 21, 2020 | 03:52 PM
LindenBruce's Avatar
LindenBruce
Does anyone have experience with these injectors? B
https://www.tamerx.com/fuel-system-i...it-155-30.html
Old Nov 22, 2020 | 06:40 AM
IHateCommieCars's Avatar
IHateCommieCars
Lol - I first read it to say "affliction". That describes me!!
I guess this leaves me with having the "affectation" for these fantastic, worry-free engines.
Old Nov 22, 2020 | 06:43 AM
IHateCommieCars
Originally Posted by SmackDaddy
The 6.0 is a love hate relationship like a good looking girlfriend that is just plain crazy...that booty though...
Once you get them lined out they are great. I did a full rebuild and my friggin oil pan leaks from the rear. So aggravating to have that issue after having it on an engine stand and rebuilt myself from the bare freshly machined block up!
How did you get her on the engine stand? I'm lucky if she straps the stilettos on when we're on vacation.
Old Nov 22, 2020 | 06:49 AM
IHateCommieCars
Mine are all original at 225k miles. My main issue is fuel economy ... it has slowly been dropping and is just about as low as I want to put up with. I have never had an issue with stiction.
I got my 450 at 144k, IIRC, and never put an injector in until around 280k when I replaced one and shortly thereafter a second. Both of which prolly only failed because I had an aux tank full of bad fuel and didn't know it. Each time I topped up from it on separate trips, I lost an injector. Realized what was happening the second time, drained that tank and replaced fuel pump and the other 6 are still good - even seem to have survived the theft that tore up the rest of the engine/turbo. I assume they are original stock.
Old Nov 22, 2020 | 07:05 AM
bismic's Avatar
bismic
I hear ya. No signs of issues other than dropping fuel economy. I am sure I could go quite a bit longer, but I really don;t want to.
Old Nov 22, 2020 | 07:24 AM
53jimc's Avatar
53jimc
I bought a new (not rebuilt) injector from Accurate Diesel for $239.95 w/ $50 core charge. I only replaced #4 since it was the only one setting a contribution code. It would run rough until it got to around 140 deg. I will save up and replace all the others at some point.
I'm not sure how I'd characterize it, affliction or affection. I know there was a lot of bad language going on while I was doing repairs, lol.
Old Nov 22, 2020 | 08:30 AM
npccpartsman's Avatar
npccpartsman
Call Casserly.
Old Nov 26, 2020 | 08:07 AM
  #28
Bitterroot Diesel's Avatar
Bitterroot Diesel
Former Vendor
I recommend the Opti-lube oil treatment in every oil change. The spool valve is what normally goes first. If you keep the valve happy and keep fuel additive in the tank you'll decrease a lot of wear.
Racecar_Dave
Jan 6, 2018 10:47 AM
Apocalypse
Sep 22, 2017 12:44 AM
63DH8
May 5, 2011 06:10 PM
desertt5
Feb 17, 2011 10:20 PM
pikiluvi
Oct 28, 2006 07:09 PM
