Time for new injectors
Old Sep 11, 2017 | 01:31 PM
Apocalypse's Avatar
Apocalypse
So the shop called and said the #5 and #7 injectors are bad. He doesn't know what injectors are in it as it has been bulletproofed. So do I buy 2 OEM injectors and see what happens? Do I buy a matching set of 8 new injectors? Is there an upgrade I can do right now to save some money later?
He also said the HPOP was starting to go. Apparently it leaks down back into the oil pan when it sits.
Old Sep 11, 2017 | 01:44 PM
2006powerstroke90's Avatar
2006powerstroke90
Since they are both on the same side, I would just do all 4 with OEM replacements and call it a day.....It would suck to do #5 & #7 and 2 weeks later #3 or #1 goes bad....Shouldn't hardly change the labor time either doing all 4 since your literally right there already.
Old Sep 11, 2017 | 01:59 PM
Excurvelle's Avatar
Excurvelle
The HPOP on 05's and up are pretty good, I will defer to the experts but it seems like something else may be wrong. Has the STC fitting been replaced?
Old Sep 11, 2017 | 02:00 PM
npccpartsman's Avatar
npccpartsman
The HPOP very rarely goes bad on the 05-07 motors. Frequently the STC fitting from the pump to the motor goes bad. If you have a leak down it's probably the oil filter housing not retaining oil, which is usually from the oil drainback valve in the bottom or aftermarket filter/cap, which I think you've already addressed.
AFA the injectors go, unless you can get hold of the previous owner of the truck to inquire, that's a hard question.
Old Sep 11, 2017 | 02:24 PM
Apocalypse's Avatar
Apocalypse
Well what should I be looking at for "performance" injectors? I can't get ahold of the previous owner so I'm afraid of putting OEM in there and the other bank have higher flow rate.
Old Sep 11, 2017 | 08:05 PM
Apocalypse's Avatar
Apocalypse
I guess I'll try OEM... riff raff the best place or do you guys recommend somewhere else?
Old Sep 12, 2017 | 05:35 AM
npccpartsman
Autonation/White Bear Lake or FICMrepair.com
Old Sep 14, 2017 | 12:01 AM
Apocalypse's Avatar
Apocalypse
After looking at all the options would I really get 3k worth of enjoyment from the 90hp injectors? Is it worth replacing all 8 with the upgraded injectors or should I just buy 2 OEM and hope more don't go out?
90HP: BD-Power 1077001 90HP Injector Set
I get 10% off for military as well
Old Sep 14, 2017 | 04:35 AM
Yahiko's Avatar
Yahiko
I think you should give Ed a call and talk about options.
You know he has all sorts of flavors from Warren Diesel
including larger nozzles.
Old Sep 15, 2017 | 02:01 AM
Apocalypse's Avatar
Apocalypse
So Ed has a backlog of calls to return... I was told it would be about a week before he could call me back so I got on the list. After some reading (and talking to Karen from FICMREPAIR) I think I'm going to go with the Warren injectors.
My questions are about the rebuild I should choose though. Part of me says "Go all in you fool!" but the part of me that listens to my wife says "You've already dropped about 2k into this thing and you should go with the less expensive ones!"
Here's the list of options:
Oem– Reconditioned Oem spool valve with tested used wires 6 month warranty.
New– New WDI spool valve with tested used wires 1 year warranty (an extra $200)
Solenoids– New Oem quality wires with reconditioned Oem spool valve 1 year warranty (an extra $400)
Premium– New spool valves, Solenoids, plugs, plunger springs and poppet springs 18 month warranty (an extra $600)
Nozzle size 30 over OEM (an extra $400)
So thoughts?
Old Sep 15, 2017 | 04:33 AM
Yahiko's Avatar
Yahiko
Well look at it this way. The top level is looking to still be less than the other guys.
Must be getting tired I have to edit this 3 times before I even hit the post button.
Old Sep 16, 2017 | 06:46 AM
WatsonR's Avatar
WatsonR
If the turbo can't keep up, large injectors are a waste of money. If you buy OEM, buy Ford remans... period! Don't waste your money on reconditioned spool valves either.
Old Sep 16, 2017 | 07:23 PM
Per4mance's Avatar
Per4mance
I concur,OEM. If you want to hot rod a 6.0 it only going to get MORE expensive down the line. Do if ya got deep pockets.
Old Sep 17, 2017 | 12:12 AM
Apocalypse's Avatar
Apocalypse
I don't plan to hot-rod my truck, but a few improvements here and there are a little different. So far this is what's been done:
EGR delete
CTS2 Edge
SCT X4 with custom tunes
Stage 2 shift solenoids (both)
S&B intake
Aftermarket exhaust (Don't know brand)
Rebuilt OEM turbo
Rebuilt FICM with 100hp PHP tune
6.4 banjo bolts
Blue spring upgrade
Fully bulletproofed
So with that list I would like to add upgraded injectors. I just don't know how upgraded I should go.
Old Sep 17, 2017 | 05:58 AM
npccpartsman
Randy has your injector answer right here.
