7.3 issue, plus others
Even f they reject the buyback you will have created a case number for your vin for the next time you have an issue.
Evidence A: Chevy trucks used to have no problems with rear seals....
My Taurus SHO went through something similar. It came out for 2010MY, and ran until 2012, when they did a small redesign for 2013. Nothing big. HIDs, LED tail lights, that sort of thing. A lot of the changes that made it to the SHO with the Performance Package was all the police stuff they added to the platform to make the Police Interceptor. Some changes to the Ecoboost, maybe the fuel system for emissions and stuff, but again, nothing major, structurally. My 2013 was recalled for two things. A leaky fuel-delivery module (the assembly that drops into the fuel tank which includes the fuel pump, float, etc), and a right-side axle shaft that, from the factory, may have had it's circlip damaged on assembly, and potentially come out. Sure did. Was really nice and wobbly when the inboard CV joint came out an inch or so... My Ford dealer (who is GREAT by the way for service, at least for $40K+ cars you buy from them) had to replace the shaft, and the intermediate shaft and bearing, seals, etc. The CV joint was wallowing out the intermediate shaft... lots of metal flying around. ON EDIT: Oh, and guess what I smelled a few days before I drove it to the dealer to get both recalls done as I walked around the back of the car to get in? Gas. When I got to the dealer, I parked it way out in the middle of an empty section of the parking lot. I told the service writer I did that on purpose, he was quite thankful.
One thing that continues as a problem with the Taurus SHO platform is the AWD PTU that drives the back wheels. For some reason, the earlier cars had the same PTU, but people are still driving around without ever having changed the fluid in it. My 2013's PTU was whining like a kid that had to pee, at around 35K miles, a few thousand before I gave it back at the end of the lease. My 2016 was OK, but that only got to 22K. Lots of people say their PTU died, just as many say they haven't had a problem in over 100K miles. My 2018 has only 7K on it now, and I plan on changing out the oil very soon. We'll see how black it is when it comes out. Long story short, something went WAY off the deep end in terms of quality control on those PTUs. There are even various engineering changes over the years, and nothing seems to have helped. On the other hand, I wonder if those engineering changes were to make manufacturing cheaper. One has to wonder.
I want a 7.3 soon. Not sure I'm going to actually get one, but I want one. I would love to see the final outcome of this, including any part #'s, TSBs, or any other info you might have that's on the receipt they give you for the warranty work.
Look how far oil pan gaskets have come. Used to be 4 piece cork and you had to cut to fit. Now they're one piece, literally lay on and bolt up. Idiot proof. Or some gaskets are just straight RTV. Again, pretty idiot proof.
There's more to why this one's failing, I'm sure.
Ford customer service reopened the case from 3 days ago and will be in contact soon. Looking for reimbursement of hotel expenses. They gave me a nice F150 to drive till repair is done.
I am going to ask about a buyback also
Thanks for all your reples
I just thought of something I didn't check on my 7.3/10 spd test drives -- does this transmission have a dipstick to check fluid level?
No dipstick, Page 370 of the manual.
AUTOMATIC TRANSMISSION
FLUID CHECK
The automatic transmission does not have
a transmission fluid dipstick.
Your transmission is filled for life, and does
not need to be checked. Your transmission
does not consume fluid. However, if the
transmission slips or shifts slowly, or if you
notice some sign of fluid leakage, have
your vehicle checked as soon as possible.
Do not use supplemental transmission
fluid additives, treatments or cleaning
agents. The use of these materials may
affect transmission operation and result
in damage to internal transmission
components.
