Membership March BS Thread
Those extra cubes really do equate to hp. Did not stroke mine but replaced rods and forged pistons and .030 over. Expect about 425 with it. Also, no roller cam.
Bet you can get the pan to work, sometimes you have to do a little creative hammer work, ouch!
Braver than I to do the assembly my friend, but I lack experience. Guess you have a manual trans? Mine is a slush box; but I will try to install a shift kit and replace the torque converter with a higher stall alternative.
Using the RPM Edelbrock pieces for heads and intake on mine. What carb have you chosen? Their 1407 here with a pcv system.
Like that you kept the heads alloy, looks really good.
Know what you mean about the budget, cause I have about 5x in my engine compared to the truck itself. LOL It is a weakness.
thanks for sharing the pics and info on your build and history. I am really liking this chapter thread as it seems to bring many of us tighter into a network, appreciate the references to your shop also. Not sure what you meant by expensive on the dyno, but would be suprised if it was otherwise. What would a guy need to do the tuning aspect while getting it broken in?
Looks like you will have one super truck when you complete the remaining work. Very nice job!
Trans is a C6. I would not say it is complicated but definitely a LOT of parts. I went with Broader Transmissions 500 HP kit and did some required modifications along with their TQ Converter. Valve body was interesting to say the least. I am not worried about the motor so much but the trans, yes....first time for both but completely different functionality. Motors are pretty straight forward. Hydraulics, not so much.
I want to say a day on the dyno is around $700 if memory serves....they don't do hourly...like I said there is a LOT of setup. Break in, on flat tappet, is simply 2,000 rpm or so for 20 minutes....pretty tough on an old motor but I did it on my 360 prior to blowing her up.
They will play with timing and jetting to show the most power. Now, if you run your carb they likely will help tune it for the engine....all things to discuss with them if you go that route. Understand a dyno vs. in the truck is different. There will be tuning and jetting changes (mostly minor) once in the truck.
The dyno will tell what max timing and jetting the motor likes. Driving it will tell you what is needed overall on jetting, and initial timing and curve wise. I am sure I left about 20 plus HP on the table not being able to tune anything. Like I said, we ran into some issues. Dropped a lifter and ended the day fairly quick. We knew we had some issues and in the end it stopped us, just in time but lesson learned. I got lucky but it cost me a good bit to fix my mistake.
425 is very doable with E-Brock heads and RPM intake. Cam grind will make the big difference. I am on some FE Forums which is why I decided to go with a custom cam. It became obvious that the cost was negligible vs a catalog cam but the gains can be huge. Simply because you are maxing out the package for what it is capable of and your use. A good builder will have a lot of data on cams and packages. I am sure ****z does, but I got my cam from Lykins Motorsports in KY.
Good luck to you, sounds like it will be a runner too! I am worried I am going to break some u-joints if it all works as planned....lot of power to push through the stock yokes.
My next learning experience is going to be paint and body.....after the engine and C6 are in and plumbing done, then that is the final step. Currently it is nice and ugly....guess you could call it a sleeper LOL. Ugly as sin but all new drivetrain front to back.
Trust me when I say this thing earned it's nickname....this is a cursed truck...the truck of 3s. Took three rear ends to make 1 that would work, and 3 engines to make 1 that was rebuildable. Before it hits the road again I think I will find a priest to do a exorcism on it.
Anybody have experience with building a exhaust on a 93 f150 4x4 with long tube headers? My son wants to put them on his truck. It currently has shortys. The part i am concerned with is bringing the left pipe across to the passenger side. He wants to run pipes like the pulling trucks, which looks like long tubes with straights down both sides to axle. I am afraid that due to the fuel tank we would have to run them too low. We have a excellent muffler shop in Walnut Ridge, but does not want to work on a "less than complete system".
Thanks
Yes, I went the simple route with my engine largely because of the rest of the truck and knowing that I would be spending alot of thought getting all of it worked out properly. Wanted the engine to be simple. Howevere, there is another block of 390 in the shop to build and will be more creative when putting it together!!
Thanks for your firsthand experience with the dyno day. That is all new to me and am glad to know that there is at least one available in the area, did not know that.
You are most likely right about the u joints too. When you put that kind of horsepower in a 50 year old vehicle of any kind, 'they won't turn and they won't stop' . VERY important to have the entire rig up to the task for more than Safety; there can easily be financial (liability) repercusions also in the event of a failure.
May have missed it, but is your truck a 1/2 ton?
Appreciate your sharing all the info, we need to talk sometime, maybe this weekend?
They may just not want responsibility for the entire job, or the 'end effect' and everything it takes to get it there; but be willing to help with what is clear and easy for them. Just my 2c.
On the oil pan. When I dyno'd my build (home built 445 Stroker) I started losing oil pressure....pumping the sump dry. The design looks good but if you start thinking about it you can see that the capacity for the rear sump is not helped by the front small sump. The design is sort of flawed but can be over come by running a lot of oil. I want to say it took 8 quarts on the dyno to stop this...FE's will have 3 or more not in the pan when running....So, given what I saw, I decided to go a different route. This is a non issue for daily driving, off road etc. and easily overcome by running more oil than it states BUT I did not like it...I just could not get over it and went with a Milodon Pan. Call it my OCD I guess...they sell a bunch of them. Mind you I am running a HV pump etc....pretty healthy build but a semi mild cam and we were turning it 6,200 plus.
