Dual Stabilizer Question
Old Mar 1, 2021 | 03:27 PM
  #61
mcmurm's Avatar
mcmurm
I just put on the Kelderman dual steering stabilizer kit last weekend. Great piece of engineering but I can attest that their instructions are terrible. I did the install myself and I'm no hercules.
Compressing the shock is tricky, but if you turn the wheel facing the shock you're installing, it requires a lot less compression to get it mounted. If needed, you could remove the tire, which would allow you more room to put your weight into compressing it. For context, I compressed it from the wheel well, not under the truck. This allows you to push forward with your weight.
Other advice would be to torque the center mounting bracket evenly from the four corners to ensure even distribution of the clamping force around the axle tube. I took some pictures here: https://www.ford-trucks.com/forums/1...l#post19755867
Old Mar 1, 2021 | 04:43 PM
  #62
speakerfritz's Avatar
speakerfritz
The shocks are supposed to have a nylon strap around them which keeps them in a partially compressed position. Install it, then remove the nylon strap. A one hand operation.
Old Mar 1, 2021 | 05:04 PM
  #63
CNLB's Avatar
CNLB
Never had death wobble, but my 2019 F350 6.7 SRW CCSB had the worse bump steer I have ever felt. I upgraded from stock 275/65R20 Michelins to 295/65R20 BFG ATs and the bump steer was much milder. I had the dealer do the steering stabilizer TSB and all of the bump steer was completely gone.
Old Mar 1, 2021 | 05:31 PM
  #64
mcmurm's Avatar
mcmurm
The Kelderman branded shocks, which are Raptor Performance with custom valving, are not strapped compressed.
Old Jun 20, 2021 | 02:24 PM
  #65
Jax0518's Avatar
Jax0518
also note....if you have a dually....you cant use a standard dual stabilizer kit...you need to order a wide track dual stabilizer kit.
This is incorrect! I have a 2008 F350, fatboy Axle (F550) yes correct, built it off ford's site when I ordered.. I use a standard kit, you have to follow the manufacture dimensions on where to place brackets outside the tie rod ends. It's slightly over 20" if I remember correctly (BDS). I have zero issues and run a 4" lift with 35's..
Old Jun 20, 2021 | 02:32 PM
  #66
KeystoneF350's Avatar
KeystoneF350
If they aren't compressed, I'd recommend compressing them by hand (push your weight down vertically to compress), and then use a couple of large zip ties to keep it compressed to make install easier. My Fox shocks had a strap to keep them compressed when I installed, which made it easier.
lwk362393
Feb 3, 2021 09:10 PM
Rockinfigs
Apr 23, 2018 09:32 PM
vento
Dec 4, 2009 01:00 PM
Robs06SuperDuty
Apr 15, 2009 12:29 PM
Joeymt3
Dec 5, 2008 01:34 AM
