Sponsored by: Real Truck
High clearance steering stabilizer???
Old Dec 1, 2008 | 10:49 PM
Joeymt3's Avatar
Joeymt3
It is time for me to replace the factory steering stabilizer. It has over 150,000 miles on it. The real reason I need it is because I hit a rock or something and damaged it.
I would like to get a dual set up. I am looking for something that will mount higher than the stock stabilizer.
Old Dec 2, 2008 | 01:56 AM
chiahunw's Avatar
chiahunw
check out the dual steering stabilizer kit from icon vehicle dynamics.
the kit puts the stabilizer shocks at the same heights as the tie-rod, one in front of and one behind the tie-rod.
Old Dec 2, 2008 | 07:48 PM
Joeymt3's Avatar
Joeymt3
Thanks for the reply, I will check out Icon.
Any one have personal experiences with they would like to share about their dual Icon set up or another brand?
Old Dec 3, 2008 | 07:05 AM
chiahunw's Avatar
chiahunw
I have the Donahoe Racing dual steering stabilizer kit on my truck. This is the same design as Icon. It's much better than stock. Actually, any aftermarket kits will be an improvement than the stock.
Old Dec 3, 2008 | 08:59 AM
Citypol86's Avatar
Citypol86
Originally Posted by Joeymt3
...Any one have personal experiences with they would like to share about their dual Icon set up or another brand?
Just put Skyjacker 7254 duals on and I like 'em. They eliminated the slight shimmy that was present with the stock single. Also, the stock single was in relatively good shape when I took it off. The duals made a difference even over a stock single in good shape.
I haven't bounced around off-road with them yet so I can only tell you about on poor, N.Y. State highways.
As you can see, height/clearance is not a problem. They're higher than the tie rods.
Hope this helps,
Later...
Brewster...
Old Dec 3, 2008 | 06:55 PM
HawaiianPSD's Avatar
HawaiianPSD
Here's a pic of the DR/ICON dual set up. Hope dis helpz.
Old Dec 3, 2008 | 07:07 PM
DCSpecial's Avatar
DCSpecial
The Icon setup is very nice, their nitrogen charged shocks work much better than hydraulic shocks.
I run Icon stabilizers on my 01 and their complete kit on my 07.
Keep in mind, any kits pictured on 05+ trucks are different than 99-04 kits.
Icon Vehicle Dynamics 1999-2004 FSD Dual Steering Stabilizer Bracket Kit - Steering Stabilizers - Truck Toyz Store
You can add the stabilizer shocks by clicking the Configure button.
Old Dec 4, 2008 | 06:05 PM
Joeymt3's Avatar
Joeymt3
the high clearance will be my highest priority. the skyjacker looks to be the best in that category. thanks to those who responded. that has helped me alot
Old Dec 4, 2008 | 06:22 PM
DCSpecial's Avatar
DCSpecial
Keep in mind Citypol86's truck is a 05.
The 99-04 Skyjacker kit hangs below the tie rod.
http://www.skyjacker.com/image/search/pdf/7299.pdf
Joeymt3's Avatar
Joeymt3
My truck is an 2003, sky jacker shows part number 7299 for mine. anyone know what is different with this one verses the 7254?
Old Dec 4, 2008 | 06:23 PM
DCSpecial's Avatar
DCSpecial
Different mounting.
99-04 goes below the tie rod.
Old Dec 4, 2008 | 06:30 PM
Joeymt3's Avatar
Joeymt3
thanks for that, it looks like the 7299 isn't what I want.
I would think that the skyjacker 7254 would fit an 03, what is different about the 05 and up verses the 99-04?
Old Dec 4, 2008 | 06:35 PM
DCSpecial's Avatar
DCSpecial
Tie rod, drag link, trac bar, front axle, etc...
The 05+ won't fit on a 99-04 with the stock steering.
Old Dec 4, 2008 | 07:57 PM
Joeymt3's Avatar
Joeymt3
I just found this picture. anyone know who makes one like this??
I have no idea what brand this is
I found the picture on this website SUSPENSION & LIFTS - Lift Kits - Donahoe Racing Suspension - Fat Boy Customs
Old Dec 4, 2008 | 08:08 PM
DCSpecial's Avatar
DCSpecial
That is an old picture of my truck.
Looks like I'm going to have to contact them about using it without my permission.
My steering isn't stock by any means:
