'20 vs '19 Comparison
Old Oct 24, 2019 | 07:04 AM
  #91
George C's Avatar
George C
Originally Posted by WVSD
I actually had them perform an “update” that took about an hour to upload into the car.
zero change. Hers shifts great other than low speed downshifts. From like 5th to 2nd. All bashing aside it literally shakes the vehicle. Also it does it 100% if the time turning off one street onto another in our neighborhood. Like going from 30 mph to 5 miles per hour then turning.
Just a guess here, but I might try to ask the dealer what particular program the later 2019’ models like ours came through with. Our build date was the 7-19. Then see if it’s a compatible flash for your truck.
honestly, what ever our Expedition is programmed with, its spot on.
  #92
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Old Oct 24, 2019 | 07:05 AM
  #93
George C's Avatar
George C
ATC, we disagree. I’ll buy, as will the rest of the nation.. It’s a truck, not a life. Now let it go.
Old Oct 24, 2019 | 07:51 AM
  #94
17 Oaks's Avatar
17 Oaks
Originally Posted by ATC Crazy
Can you get your head any further in the sand? Your one or two personal experiences that are positive doesn't give you the reasoning to tell the other hundreds of thousands of owners that they are wrong and stupid. You are in extreme willful ignorance sir.
But muh 9 MILLION MILES! All of that testing doesn't mean the vehicle will have no faults. Yeah, I'm sure Ford tested their light duty 10-spd a lot too...it had issues at launch. How about all that testing on the 3V Triton engines that don't like spark plugs? How about all the testing on the new 6.0PSD? 6.4? How about those early Raptor frames? I'm sure GM tested the hell out of their 5.3/6.0 engines, only for them to burn quarts of oil...completely normal though, right? Dodge probably did a lot of testing on their automatic transmissions in the past too....didn't work out too well for them.
And if you think the 2020 6.7L is "basically the same", you should re-read and re-watch some videos on it. Just about every moving part inside and outside is new. Pistons, rods, oil pump, turbo, fuel system, injectors, etc...
We didn't "forget about the quality we know", YOU forgot that first year vehicles have a proven history of having more issues than later versions. THIS is what the OP needs to know, and is what he needs to keep in the back of his mind. If the thought of having a brand new generation of truck is worth the small increase in potential issues, then that is his choice to make. Considering his planned use of the new truck, I would advise against the 2020. I provided proof. You did not. Google & Bing can even back me up.
But muh 9 MILLION MILES is proof, right?!
Nope. That just means it's good enough to bring to market.
There's a huge difference between a Ford engineer testing a prototype pickup in a controlled environment....and having hundreds of thousands of civilians, from oil patch workers to soccer moms testing it.
9 MILLION MILES!
The 2020 6.7 is Gen 3 and its still the same engine with new and improved components. Gone from Alum pistons to steel etc. This is the normal progression by any manufacturer that chooses to produce a quality product for the market place and the fact that Ford had done it is less than 20 years without trying to fix major problems in the engine only tells me of Ford's commitment to this engine and its commitment to quality and value for its customer base.
Without a doubt, there is a huge difference between prototype testing and fielding ...I spent a career as an engineer in Research, Development, Testing & Fielding, you clearly have not! The fielding is the 2nd phase of the testing loop and is ever ongoing. Its a loop, from us folks on the R&D&T side to the end-user and we capture that data from their use and return it to the R&D&T side, this is how we get to Gen 3 and beyond. You might note the Chevy V8 as released in 1955 was improved upon but remained the same basic engine thru the 2015 model year. The oil patch worker to soccer mom is extremely important due to it not being a controlled environment. Companies that do not capture that valuable data generally produce poor products and all they do is come out with an "all new" product every few years. Ford truck does not work that way which may be why they are the best selling truck for over 42 years in a row.
FYI . The truck market is Texas where trucks have always outsold cars. I grew up on a ranch and we and every rancher I knew drove Chevy, GMC or Studebaker, nobody drove Fords except 'sharecroppers'. Ford was JUNK, Rusted out before it was sold off the lot, burnt more oil than gas. Ford figured it out and is still winning 42+ years later!
Old Oct 24, 2019 | 06:03 PM
  #95
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Says the man who always has to have the last word. Oh, wait a minute...
I wish I could get to the level of thought, where I can disagree with decades of proof, over hundreds of models, with research done by multi-million and billion dollar companies using information from tens of millions of owners over the years...
But nah, that stuff don't matter...I had a couple good first model year trucks so everyone else is wrong...
I bid you adieu. I am "letting it go" Good day to you sir.
Old Oct 24, 2019 | 06:19 PM
  #96
George C's Avatar
George C
ATC, let me buy you dinner somewhere. I’ll send you a gift card to bury the hatchet.
Good luck OP...if you’re still around.. I hope you have the best of luck, which ever you choose.
Don has a VIN.. I’m still waiting..grrr...
Old Oct 24, 2019 | 06:20 PM
  #97
System's Avatar
System
Prolocutor
With all due respect to both sides of this debate... I agree with both of you. One important thing that hasn't risen to the surface here from either side is this...
I think we can all agree that new model year vehicles are indeed more problematic. Stats don't lie on that front. However, how much more? 1%? 5%? 10%? etc. That said, what is each person's tolerance towards that risk? For me personally, I'm in George's camp here. Sure, there is an increased risk of new model year issues but I'd be willing to take that very small chance to get the latest and greatest. On the other hand, people with more patience than I (or George) are likely rewarded with slightly lower level of risk of having an issue... and if you're the one that get's bit by said possible issue, you'll certainly wish you had waited. Bottom line is I think you guys are both right. Sure, 1st year vehicles generally have a few bugs that get worked out by year two. But, that same risk is also a very small one and many of us would take it to get what we want now.
Old Oct 24, 2019 | 09:21 PM
  #98
2013xlt's Avatar
2013xlt
I agree with everything you said. And is up to each person to decide if they want to take a little more risk on a first model year, most people won't have issues. I for one will wait a bit but that's not saying that you are wrong to buy right out of the gate.
The one thing that's misleading about the 9 million miles is that all that testing is done on pre-production trucks and manufacturers almost always change suppliers for different parts to cut cost for the actual production vehicle and a lot of times that is where problems or bugs will arise.
Kevin's dad
Nov 24, 2018 09:27 PM
Big-Foot
All Things Towing
50
Jul 14, 2017 08:32 PM
rangerbait
All Things Towing
18
Jul 14, 2015 02:51 PM
j4henry
Jun 10, 2011 09:54 PM
gr8scott72
Jun 29, 2009 08:10 AM
