AWD vs 4WD
Old Jul 11, 2019 | 09:31 AM
JALinker's Avatar
JALinker
AWD vs 4WD
I am looking at an 2011 F150 Limited... this model only (that I have seen) has the 2H, AWD, 4H transfer case... is it possible/feasible to change the transfer case to a later one that has 2H, AWD, 4H and 4L? or a same year case that is 2H, 4H, 4L (loses AWD)?
I love the looks of this specific model, colors, wheels, the lusty 6.2, etc... but really feel like will want/need 4L on occasion...
Any pointers?
Thanks in advance!
Old Jul 11, 2019 | 09:50 AM
ford390gashog's Avatar
ford390gashog
Yes I did the swap in 2014 on my 2011. It was all bolt in and I used the 2012+ transfercase which has 2Hi,4A,4Hi & 4lo. All you need is the transfercase and the dash switch. You will also need forscan to change the transfercase type in the TCCM which is the hardest part.
Old Jul 11, 2019 | 09:54 AM
JALinker's Avatar
JALinker
holy crap! That is great news!
Thank you!! I will definitely look more into the AWD truck now! This has made my day!!!
Old Jul 11, 2019 | 01:14 PM
steve(ill)'s Avatar
steve(ill)
I guess I didn't know that FORD built a F150 without LO gear..... what was the point of that ?
Old Jul 11, 2019 | 01:27 PM
JALinker's Avatar
JALinker
I'm with ya... I don't see the point, myself... if you want 2WD, get 2WD... 4WD should be 4WD---with auto, neutral and low...
When is the last time an F had a Neutral?
00t444e's Avatar
00t444e
I didn't know that either, what a stupid idea, Its probably the same transfer case used in the Navigator.
Old Jul 11, 2019 | 05:54 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
That's great news to know it's possible to change it to the 12-14 case with 4L.
I was a tad worried when I bought my '11 limited about not having 4-Low but with the super low first gear and elect shift transmission and the TQ the 6.2 puts out I've never found a time I needed it in the last 5+ years and 45k miles.
Mine spends half the year in the Auto setting which works amazingly well compared to the old control trac systems in the older explorers and expeditions.
ekkavan
Aug 16, 2014 08:57 AM
rdmobile
Dec 1, 2013 10:37 PM
dybeepvw
May 15, 2011 11:10 PM
Katmandu
Nov 2, 2005 09:46 PM
termyt00
Nov 30, 2003 08:49 PM
