Help! Transfer case grinds when.....
Old Nov 2, 2005 | 10:55 AM
Katmandu's Avatar
Katmandu
Question Help! Transfer case grinds when.....
....the lever is pulled into 4WD mode. 1985 F150.
What's going on here ??
Old Nov 2, 2005 | 01:44 PM
kopfenjager's Avatar
kopfenjager
What transfer case is it?
Old Nov 2, 2005 | 05:48 PM
Katmandu's Avatar
Katmandu
Question
No idea.
What would cause it to grind ??
Old Nov 2, 2005 | 05:56 PM
andym's Avatar
andym
It's probably an NP208.
I don't think anyone's going to be able to guess. I bet if you take it apart the reason will become fairly obvious.
Old Nov 2, 2005 | 06:08 PM
Katmandu's Avatar
Katmandu
Question
It's in a truck I'm looking at possibly buying.
Are there any diagrams of the NP208 or other transfer cases here On-Line ??
Old Nov 2, 2005 | 07:55 PM
ivanribic's Avatar
ivanribic
Are you certain that the grinding noise is coming from the transfer case? Sometimes a bad hub will grind when 4x4 is engaged or dirty hubs may not fully engage, causing that noise. Just wanted to throw this out for thought.
Old Nov 2, 2005 | 09:46 PM
Katmandu's Avatar
Katmandu
Question
Not for sure yet. I haven't seen the truck yet. Was just told about it in an Email.
What would cause the hubs to grind when shifted into 4WD ??
