Sponsored by: Real Truck
Transfer case questions
Old Nov 30, 2013 | 05:10 PM
rdmobile's Avatar
rdmobile
Just bought a f250 this year which replaced my Jeep. The Jeep had a full time transfer case, well to be clear it allowed 2WD, fulltime 4WD, 4H, and 4L. I really liked the fulltime 4WD. Was a nice feature to have. I of course miss it and have been compteplating if it would be possible to outfit my F250 with a similar transfer case. The jeep case would of course not work in a heavy duty application.
Does anyone know if such a case exists aftermarket or via a junkyard swap?
Old Nov 30, 2013 | 06:24 PM
PSDlongbox's Avatar
PSDlongbox
It would be quite a project. The f250 chassis does not come with a center differential which would allow the front and rear to travel at different rates of speed.
Old Dec 1, 2013 | 05:43 AM
Desert Don's Avatar
Desert Don
You might try advance adapters and see if they make something; but they won't be cheap by any means.
Old Dec 1, 2013 | 05:50 AM
HeavyAssault's Avatar
HeavyAssault
The MPGs would drop off as well with a fulltime case. Fulltime 4x4 is nice when you need it for daily driving. For my needs fulltime would not be worth it at all.
Old Dec 1, 2013 | 09:54 PM
rdmobile's Avatar
rdmobile
maybe but...
with the jeep t-case/setup you could actually just run 2wd. As you may say there may have still been some added drag. The jeep's mileage did not change much from 2wd to 4wd.
Also no need for a center diff so to speak the jeep t-case was about the normal size for a t-case. I think it used visous coupling. Either way if there was a heavy duty version of this case it looks like it would be a pretty straight forward swap.
Guess Ill look around some more but sounds like I will just have to get use to this ol' timey 4wd system. Glad its not my daily driver.
Old Dec 1, 2013 | 10:37 PM
rdmobile's Avatar
rdmobile
after some more research I am suspecting the jeep case was as you described full time and may not have really had a 2wd mode. Would make sense with the milage, but then again I ran oversized tires which screwed my mileage from the start.
I wish I could remember the exact number of that case, I think it was a NP243. Which actually from some light research sounds like it came in some 3/4 and 1 ton chibbies.
Back to google I guess.
parrothead85
Jan 22, 2013 08:27 PM
78 RedandWhite
Jan 31, 2011 07:29 AM
Katmandu
Nov 19, 2008 08:38 PM
Katmandu
Nov 2, 2005 09:46 PM
Supercab
Dec 16, 2001 01:52 PM
