1978 - 1996 Big Bronco
E4OD Help Needed
Old Jun 24, 2019 | 09:02 PM
Deadsquiggles's Avatar
Deadsquiggles
E4OD Help Needed
So a year and a half ago, my E4OD went out again and it went down to just 1st, 2nd and Reverse with no forward movement if I put in Drive so unless I’m missing something, I imagine I need to either rebuild what I have or buy a new tranny.
Anyhow,I’m finally getting the motivation to start messing with the truck outside of just starting it and letting run every week. So what’s recommended for a rebuilt E4OD, rebuild kit, or a good transmission specialist near Chesapeake, VA that won’t break the bank. It has a 302, 33’s, and 4.56s, just in case it matters. Overall, I’m just as okay with buying a good, well put together rebuild kit and having it installed as I am buying a complete tranny. The main goal is a reliable transmission that won’t cause me to get divorced. I’d like to be at or under $2000. Not sure what rebuild kits are good or what to look for in a kit.
I’ve seen Monster Transmission but I actually can’t find more than one or two reviews for them and I’m not too familiar with transmission shops around me. But any help would be greatly appreciated.
Old Jun 25, 2019 | 09:09 AM
AbandonedBronco's Avatar
AbandonedBronco
Have you checked to be sure it's not your transfer case, and not the transmission?
If the transfer case isn't shifting properly, and is stuck in neutral, etc. it doesn't matter what gear your transmission is in, the vehicle won't go anywhere. It'd be odd for no gears to have any forward movement.
It'd be a shame to fully rebuild/replace the transmission, and still have the same issue because the transmission wasn't to blame.
As for the transmission, here's a little bit of troubleshooting to see what the issue may be: Common Customer Problems With The Ford E4OD Transmission
Old Jun 25, 2019 | 12:46 PM
Redark1's Avatar
Redark1
there is more info on here to help with your troubles. almost sounds like a solenoid pack prob. are there any codes. really need to check for those on this one.
Old Jun 25, 2019 | 09:18 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Let's make sure I understand what's going on.
The trans works in reverse and when the shift handle is in 1 or 2. If you put it in D it won't go. Is that correct?
If that is correct pull the transmission and rebuild or replace it. The overdrive one way clutch has failed. Don't listen to those that tell you it could be the transfer case or the solenoids. It can't possibly be either of those.
Old Jun 26, 2019 | 06:35 AM
Deadsquiggles
Yeah only moves if I shift to 1st, 2nd or Reverse. If I shift to drive, the engine just revs and the truck doesn't move. I'm figuring since it needs a rebuild or replacement, I'll go ahead and get it rebuilt so I can pick exactly what goes in it rather than hope that whatever replacement transmission I would potentially buy has good parts. Problem I'm running into now is that I don't know exactly what to upgrade or where to find parts. I've read that some of the internals for the 4R100 transfer over and are stronger but I'm not 100% what can be swapped. Transmissions are like voodoo to me. But I defiinitely want to upgrade internals while it's apart seeing as eventually I'd like to replace the stock 5.0 with a warmed up 5.8.
Old Jun 26, 2019 | 09:21 PM
Mark Kovalsky
Pretty much everything from a 4R100 can be swapped into an E4OD.
Old Jun 26, 2019 | 10:08 PM
Tim Hodgson's Avatar
Tim Hodgson
Good to know!!!
Thanks!
Old Jun 27, 2019 | 07:20 AM
Deadsquiggles
Yeah, very good to know that because it seems like the 4R100 is better in almost every way. What exactly from a 4R100 should I include in the rebuild?
Old Jul 21, 2019 | 02:45 PM
Deadsquiggles
So the weirdest thing happened today. I went out and started the BKO (as I do every weekend) and moved it from the back of the property to next to the garage so I could keep an eye on it. So after half an hour and letting it get up to operating temperature, I put it in reverse to back up where it sits next to my shed but decided I wasn’t lined up where I wanted. So about of habit, I put the truck in Drive and it went into gear and MOVED!!!!!
So I don’t want to fill myself with false hope, but could this actually mean I don’t need a new tranny, but that a connector or sensor is bad?
Old Jul 21, 2019 | 05:25 PM
Mark Kovalsky
There is nothing electronic that can keep the trans from engaging in forward gears. It has to be mechanical.
It could be loose feed bolts, or a bad seal in the forward clutch.
Deadsquiggles
19
Jun 28, 2019 07:10 PM
wacastillio
Oct 15, 2018 08:14 PM
tonyjklh
Feb 26, 2015 09:32 PM
Dave7.3
Apr 15, 2009 12:13 AM
knapikmichael
Apr 2, 2007 06:26 PM
