should I rebuild E4OD
Old Feb 15, 2015 | 10:29 AM
tonyjklh's Avatar
tonyjklh
ok so I will have to pull my transmission out soon due to a bad converter. the converter has a squealing noise when locking up (and of course doesn't lock up very well). I'm assuming the clutch is pretty well gone in the converter. now my question is whether or not I should just rebuild the whole transmission while I've got it out. I will note that this wouldn't be my first E4OD rebuild.
for the most part my transmission seems to work good. firm 1-2 shift, but very soft 2-3 and 3-4, and reverse with double bump/feels like double engagement-when shifting into reverse the first bump is practically instant, and the second bump with full engagement is about two seconds after.
what do you think? rebuild? or should I just fix up the accumulator to firm up the sifts(I'll use the Sonnax accumulator valves for this)?
thanks for any advice!
oh and its a 1993 F150 5.8 4X4, 200,000 on the truck but not sure how much is on the trans.
Old Feb 19, 2015 | 04:53 PM
tonyjklh's Avatar
tonyjklh
well, I guess no one has any suggestions.
I've decided I'm just going to rebuild it. I figure even though its not bad yet it probably isn't too far from getting there. I'll be doing several upgrades during the rebuild, but unfortunately my budget is already reaching its limits and I wont be able to do all the upgrades I'd like to.
Old Feb 19, 2015 | 05:52 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I didn't see this before. I recommend rebuilding it.
Old Feb 19, 2015 | 06:44 PM
tonyjklh's Avatar
tonyjklh
Thanks, I will definitely be rebuilding it. I've already got everything I should need ordered.
what's your opinion on doing the center support upgrade? I understand that the bearing version is a lot stronger and longer lasting but is it really worth it?
Old Feb 19, 2015 | 08:28 PM
Mark Kovalsky
I don't know enough about that upgrade to comment on it.
Old Feb 26, 2015 | 08:27 PM
Fishin76's Avatar
Fishin76
Mark, what would you recommend for upgrades for the 4r100?
I'm already planning to upgrade the TC with a triple disc unit, use the transgo kit to convert the PWM converter control to on/off instead of the stock pulse modulated setup, and install the transgo HD2 tugger shift kit. Also plan to use the bonded accumulator pistons, and the spiral snap ring for the OD retainer.
Pump will get new gears, and new valves, springs, bushings. (basically rebuilt, with more flow).
I have a (what i think is) a quality rebuild kit picked out. I have a tuner on the truck, but my mods are light, no big injectors, or dual hpop setups, just a nice boost via the chip. I am also going to follow the ATSG rebuild guide as close to the letter as I can ( some special tools I will not be buying).
Ya, you could say that I want to upgrade anything that will increase durability, and performance, as a side benefit.
Thanks in advance!
Old Feb 26, 2015 | 09:32 PM
Mark Kovalsky
I don't have a good handle on upgrades.
rupejosh
Jun 30, 2022 07:57 PM
wacastillio
Oct 15, 2018 08:14 PM
RP27G8G
Jan 28, 2008 11:05 AM
tunruh
Mar 11, 2005 11:47 AM
trannyhell
Jul 2, 2001 02:40 PM
