Converting to Electronic Distributor
Old Apr 28, 2019 | 06:20 PM
Knockonwood's Avatar
Knockonwood
What do I need to convert to electronic distributor on my 62 F100 with 292 yblock?
Old Apr 28, 2019 | 06:48 PM
Tedster9's Avatar
Tedster9
Some kind of module, like the Pertronix Ignitor for example. It is a drop in replacement for the points & condenser. Part #1281 iirc. (Ford used the same points from '57 to '74 or somesuch, at least in V8, so that's what Pertronix offers for pretty much everything Ford.) You can use the existing ignition coil and the rest of it if you want. 20 years in my Y-block, never missed a beat.
Old Apr 28, 2019 | 06:56 PM
ford390gashog's Avatar
ford390gashog
I gave up fighting the old worn 292 distributor. For not much cost I went with a full new small cap HEI distributor, coil and 8mm wire set. Been very happy with it and have used it on two other Y blocks so far with no complaints. Click Here
Old Apr 30, 2019 | 10:11 PM
Knockonwood
Thank
Thanks for all the information. I think I have it now!
Old May 19, 2019 | 11:52 AM
HT32BSX115's Avatar
HT32BSX115
You can also get it directly from the Manufacturer. https://crtperformance.com/shop?olsPage=products
Old May 21, 2019 | 03:51 PM
wellcraft17's Avatar
wellcraft17
X2, on the pertronix 1281, got tired messing with points, condensers and installed the 1281 back in the early 90s. I’ve never had a problem and it was a simple installation.
jeffcole1970
Dec 17, 2013 02:55 PM
jerry73
Jan 13, 2013 12:01 AM
Rust is too a color
22
Jan 17, 2012 05:23 PM
daniel1982
Apr 26, 2011 04:41 PM
OzarksFord
Oct 2, 2005 11:40 AM
