Lost reverse today - options?
Old Apr 1, 2019 | 12:04 PM
  #31
queen of spades's Avatar
queen of spades
Dropped truck off at A1 this morning. Chris was very knowledgeable and professional, and answered all of my questions thoroughly. Shop looked super clean as I'd read.
In addition to the bulletproof transmission and 6.0 cooler install, I'm having him replace the up-pipes with bellowed units (stockers leak right now), and also replace u-joints and balance the main drive shaft.
Old Apr 1, 2019 | 12:25 PM
  #32
queen of spades
Just for kicks here's a list of threads that mention Chris Garret and A1 Transmission over in Flowery Branch GA.
Old Apr 4, 2019 | 11:01 AM
  #33
queen of spades
Old 4R100 removed from the truck
This transmission was fubared in many ways
This transfer case plug was broken and sealed with RTV.
Good time to fix those leaky up-pipes
New bellowed up-pipes installed
Bulletproof Transmission from A1 in Flowery Branch, ready to install
6.0 trans cooler on top, stock on bottom.
Old Apr 4, 2019 | 11:08 AM
  #34
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Wow, looks like the new parts were well needed. Thanks for posting pictures and a brief explanation.
Be sure to let us know what you think once you are back in the driver seat.
Old Apr 4, 2019 | 01:54 PM
  #35
Bonanza35's Avatar
Bonanza35
Looks good. Let us know how you like it.
Old Apr 4, 2019 | 02:20 PM
  #36
queen of spades
A1 believes my rear diff is overdue for overhaul. They suspect the inner carrier bearing is bad due to some grumbling/rumbling at certain speeds.
My differential is the 10.50"/3.73 with ID S409H. Is there a way to see what other 3.73 IDs interchange with this one?
Old Apr 4, 2019 | 03:57 PM
  #37
Bill Kay's Avatar
Bill Kay
Chris does great work and builds as good a transmission as anybody out there. A friend of mine beat on one of his transmissions with close to 500HP 7.3PSD for about 2 years and when he sold the truck the trans shifted and preformed as good as the day he put it in. Boosted 4wd launches and wide open runs from a stop daily. Another friend just had his done by Chris just recently and he gave him a military discount.
You will be happy with it.
Old Apr 4, 2019 | 07:32 PM
  #38
bigb56's Avatar
bigb56
It looks like you made the right choice, will be looking forward to see how you like it. I figure eventually I will have two big expenses on my truck, injectors and transmission. I will seek out the best as you did without hesitation, no new truck for me I already have the best one.
Old Apr 5, 2019 | 10:07 PM
  #39
queen of spades
Got the truck back today. Transmission feels great. The old one used to have nearly a second pause before reverse would catch (this was true even when I bought it). A1's Bulletproof trans works perfect. Shifts are quick and not too abrupt.
Going to continue breaking it in a little before I haul anything heavy.
Old Apr 5, 2019 | 10:09 PM
  #40
queen of spades
Also they said to basically turn overdrive off when towing heavy stuff. Also, as others mentioned earlier - never use engine braking at anything higher than 35mph. Doing so will wreck the transmission.
They put in Dex III instead of Mercon V as before.
  #41
Sous's Avatar
Sous
FTE Emeritus
Congrats and well done on getting it back on the road so soon!
Old Apr 19, 2019 | 09:39 AM
  #42
queen of spades
Quick update. The new transmission is working great. My old one would take a while before going into gear, especially if it was cold.
New one instantly goes into gear no matter how cold it is. I've pulled a few moderately heave loads after break-in, and have had zero problems.
I'm also making sure to turn off overdrive when towing heavy stuff, and also, when backing up with a load to use 4x4 low (even with the front hubs off).
schmeck
2004 - 2008 F150
Jun 25, 2015 05:53 PM
lionsteve
Nov 28, 2012 09:23 PM
darkmage55
1997 - 2003 F150
Mar 11, 2010 10:07 AM
wrdude
1983 - 2012 Ranger & B-Series
13
Jun 7, 2009 09:34 AM
ponyrider
Escape & Escape Hybrid
Dec 7, 2008 09:20 AM
