Rebuild time
Old Apr 20, 2019 | 07:36 AM
  #91
Eaglescout94's Avatar
Eaglescout94
Does it feed in from the rear of the engine going forward when fully assembled? I didn’t follow directions when i removed it and it still had the oil filter installed, dumb idea, it didn’t want to come out together.
Old Apr 20, 2019 | 08:10 AM
  #92
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Yes, fed from the rear of the engine toward the front fully assembled.
Old Apr 20, 2019 | 11:26 AM
  #93
Walleye Hunter's Avatar
Walleye Hunter
I hear these stories about how hard they are to get together...how hard are they to get apart?
Old Apr 20, 2019 | 11:32 AM
  #94
Sous's Avatar
Sous
FTE Emeritus
The only reason they are tricky to get together is because the 4 o-rings are fresh plyable instead of being compressed and brittle.
Taking them apart is usually very easy.
That said, constant pressure from s strap with a bit of blunt force from a rubber mallet and the caps pop on. Make sure the o-rings are lubricated though with your favorite flavor. I use the Permatex engine assembly lube because it us sticky enough to hold gaskets or o-rings in place, but slippery enough to make installation easy.
Old Apr 20, 2019 | 11:56 AM
  #95
Eaglescout94
I’m hoping it goes together with the correct o rings as easy as it went together with the wrong. Didn’t take all that much force to pop it together, using a ratchet strap and a few blunt hits with a mallet should make it super easy
Old Apr 30, 2019 | 08:49 PM
  #96
Eaglescout94
This wont be a bit by bit list but ill try to make it easy to understand.
$1,160 - random seals, exhaust bolts, billet plenums, bearings, oil cooler and pump, o-rings
$1,870 - complete engine gasket kit, IH water pump, CNC fab 4 line fuel kit, chromoly push rods, ARP head studs, CNC fab HPOP lines
$444 - new oil pan, pan gasket, quarter turn drain valve, upgraded valve springs
$1,118- reman heads
$200 - engine paints, oil, oil filter, coolant
$1,895 205/80 injectors
This should be everything that it took to get it together so long as I don’t screw up.... unfortunately i broke the rear oil cooler cap/ filter mount so that and new o-rings and gaskets cost another $364. So we have a total of around $7,050. I didnt need any machine work done and the pistons and rings were not tampered with. There’s probably some parts in forgetting so throw in another $250 and everything should be covered..
Old May 1, 2019 | 07:58 AM
  #97
Walleye Hunter
Interesting price for that oil pan. You didn't replace the rings?
Old May 1, 2019 | 09:27 AM
  #98
Eaglescout94
I got the moroso pan and gasket. Nope, I wasn’t burning oil before and I didn’t see anything wrong looking at them. My engine friend said they’d be good to go. So far so good, the power is nice but I couldn’t try it out as much as I would have liked since it was wet out
Side note that I somehow forgot about, it sure would be nice if the aftermarket guys made sure their products played well together without modification, I had to do some material removal on the billet intake plenums to get the fitting to thread in well for the CNC fab 4 line kit. Without doing so the fitting might have had 2 threads holding it in and I wasn’t comfortable with that little engagement.
Ford4Life7.3
25
Oct 27, 2014 05:09 PM
Lowered70
May 12, 2005 12:21 AM
netlans
1978 - 1996 Big Bronco
Nov 14, 2002 08:54 PM
BEAVER
Oct 28, 2002 05:40 PM
x_FordMan_x
Jan 1, 2002 04:00 AM
