Method Wheels
It would be much appreciated….
17x8.5..?
The ride definitely changed . You cant take away that these are 3/4 ton trucks with suspension designed around carrying weight vs a plush ride. Right now i have 50 PSI up front and 45 PSI out back. There are certain things I dont feel in the road any more when compaired to the stock 20's with 65 PSI. A good example would be a rail way crossing. The higher volume tire is absorbing a good amount of the initial hit while the high rate springs still have a strong rebound. The rear doesnt bounce as much either. The same rail way crossing with 20's at 65 PSI I would have bounced in my seat a little.
As far as handeling I havent felt a difference. There is a curve I take everyday at 50 MPH and the truck isnt leaning any different than with the stock wheel/tires. These are E-rated tires so the side walls are stiff. When I haul material I air up the rear tires (these are E2 rated tires so 65 PSI MAX) and still have good handeling.
I can only imagine if you are towing super heavy loads a long distance that you would have some wondering... maybe?
My final thought is that the higher volume tires at a lower PSI softened the ride a little but ultimatly the high rate springs are the bigger determining factor to ride quality and handeling.
...Thanks ...I Appreciate it...
Again, thank you!
