Method Wheels
Old Feb 2, 2021 | 10:21 PM
  #91
wheresjames's Avatar
wheresjames
Sold my 605s and went with an entirely different look with the 315s.
Old Feb 2, 2021 | 10:23 PM
  #92
OffRoadRN's Avatar
OffRoadRN
Looks good. I can't decide if I want to go with machined or black wheels.
Old Feb 3, 2021 | 12:37 AM
  #93
wheresjames
Thanks. It’s a tough decision for sure.
Old Feb 3, 2021 | 07:47 AM
  #94
rigman44's Avatar
rigman44
17" methods on 35's. 4" lift I painted the outer ring black.
Old Feb 3, 2021 | 08:52 AM
  #95
wheresjames
what was your process to paint the rings?
also, did you paint your front hubs?
Old Feb 3, 2021 | 09:12 AM
  #96
OffRoadRN's Avatar
OffRoadRN
Looks great. Are there any downside to 17 inch wheels? I'm thinking about doing the same to get a little bit more sidewall. Are those wheels hub centric? Do 17 inch wheels have a lower carrying capacity?
Old Feb 3, 2021 | 09:18 AM
  #97
rigman44's Avatar
rigman44
I taped off the wheel and shoved 3x5 index cards between tire and wheel to prevent overspray on tires. The bolts are removable, so I removed them all and then scuffed the ring with some 400 grit sandpaper. Spray painted with VHT wheel paint., reinstalled the bolts. 9 mos in and no chips yet. Shot the hubs with same paint.
Old Feb 3, 2021 | 09:26 AM
  #98
rigman44's Avatar
rigman44
Im not sure of any limitations with the 17's, The bigger sidewall and a milder tire made the ride wonderful compared to my old setup with 37's on 20's. Quiet and comfortable now. Not sure on the carrying capacity and these are lug centric, not hub centric. .
Old Feb 3, 2021 | 09:39 PM
  #99
Loser1's Avatar
Loser1
Trailering
Obviously not a truck but here are my 101s....
Old Feb 4, 2021 | 05:01 PM
  #100
14&Ford's Avatar
14&Ford
I had a question...I am looking at getting a set of Method 305 NV, is it worth the extra $50 per wheel to get the HD version? I have a F250 coming in and don't know if I need the 4500 lb rating of the HD wheels vs the 3640 lb rating for my truck. Thanks!
I am in the market for wheels as well. i have a big camper that i haul in my bed so for me i would spend the extra$50 per wheel and leave nothing to chance.
Old Feb 4, 2021 | 05:03 PM
  #101
14&Ford's Avatar
14&Ford
Old Feb 4, 2021 | 06:19 PM
  #102
OffRoadRN's Avatar
OffRoadRN
Yeah I guess I was thinking that since I am getting an F-250 my payload might be restricted enough that I don't need HD wheels. But I guess you're right, for 200 bucks why risk it.
Old Feb 4, 2021 | 11:43 PM
  #103
Jimdogsr1's Avatar
Jimdogsr1
Wheel and tire combo look really good.
Old Feb 5, 2021 | 11:05 AM
  #104
T. Banning's Avatar
T. Banning
Originally Posted by ninthwonder
18 method nv
I'm still an old school, I like the looks of aluminum wheels, but I love this camper shell! And the DU head on the back! 👍
Old Feb 5, 2021 | 11:55 AM
  #105
T. Banning's Avatar
T. Banning
You can also put vaseline on the tires, and that will prevent the paint from sticking, then wash it off after your paint has dried!
