Method Wheels
Old Feb 11, 2019 | 12:43 PM
  #31
jrwinger's Avatar
jrwinger
Anyone have a magnetic truck with Bronze Methods? I'd love to see how it looks. Thanks!
Old Feb 13, 2019 | 10:56 AM
  #32
garretblack's Avatar
garretblack
Method NV HD 18x9 +18
Goodyear Duratrac 35x12.5x18
No lift or level but do have snow plow front springs
I was hoping the caps were a little easier to take off or get your hand into so I left mine off the front which seems to be about 50/50 here. No way I want to be guessing which Allen bolts are real or fake (only 3 actually hold the cap on) if I'm stuck and then it looks like you can barely get your hand in there if the cap is off.
Old Feb 13, 2019 | 01:14 PM
  #33
brainofjjj's Avatar
brainofjjj
That front cap would cut the absolute **** out of your hands too, no way i was gonna leave that on
Old Feb 16, 2019 | 05:32 PM
  #34
Cohlmeyer's Avatar
Cohlmeyer
Originally Posted by Joe T
Whats your suspension setup? Looks good.
2” bds level. New Carli springs and fox shocks come in this week. Didn’t care for the shocks the bds kit came with and want to get rid of the spring spacer. Should ride a lot better also.
Old Mar 3, 2019 | 12:03 PM
  #35
Bealsbks's Avatar
Bealsbks
do you have any pics of the side and front of you truck with those 18''? Would like to see how flush the 35 x 12.5's are with that offset.
Old Mar 3, 2019 | 12:52 PM
  #36
JAA 2017's Avatar
JAA 2017
So is everyone running Methods using the hub-centric rings?
Old Mar 3, 2019 | 01:36 PM
  #37
Cohlmeyer's Avatar
Cohlmeyer
No, their center cap is the centric ring according to them, but their lugs also center the wheel. Per them they don’t make a dedicated ring nor do you need one.
Old Mar 3, 2019 | 02:18 PM
  #38
lasallen's Avatar
lasallen
I just recently updgraded from the 2" bds level with fox shocks to the carli commuter with add a packs in the rear. I can honestly say the ride quality has not improved at all since the switch. I guess i need to try the full leafs in the rear.
Old Mar 3, 2019 | 04:11 PM
  #39
Cohlmeyer's Avatar
Cohlmeyer
Originally Posted by 18six7bruh
Method 305 NV HD Matte Black 17"
is this leveled or lifted?
Old Jan 27, 2020 | 01:39 AM
  #40
daletodd2's Avatar
daletodd2
Anyone else?
Old Jan 27, 2020 | 06:35 AM
  #41
FractureCritical's Avatar
FractureCritical
I had method wheels on my 01. Double standards and they were really nice. My only complaint is that the bolts around the rim we’re a total pain. They’re cadmium plated steel, so they rust after the first winter, they’re shorter than commonly available bolts (they are even custom stamped for Method!) so even if you wanted to replace them with stainless, you’d have to buy stock bolts and cut_each_and_every_one by hand. They also fall out from time to time which messes with the balance.
Old Jan 27, 2020 | 06:28 PM
  #42
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Attachment 281837
Attachment 282250
Old Mar 10, 2020 | 10:47 AM
  #43
daletodd2's Avatar
daletodd2
Gotta stop looking at this thread. anyone running 20x10 605s with 35's?
Old Mar 10, 2020 | 10:54 AM
  #44
lasallen's Avatar
lasallen
I just ordered 20x10 -24 offset 605's with Ridge Grappler 325 60 20's which are equivalent to 35.5 x 13 x 20
Old Mar 10, 2020 | 11:01 AM
  #45
daletodd2's Avatar
daletodd2
oops I meant to say 20x10. Post up here when you get them installed! I'm ordering the exact same set up late next month.
