Does anyone have 20x9 wheels with 295/65R20 mounted on them? I’d love to see it. I think I’ve found every other close combination under the sun, but can’t find this one exactly.
yes, look at my truck in this thread,
20x9 method
295/65/20 Toyo AT
I just recently updgraded from the 2" bds level with fox shocks to the carli commuter with add a packs in the rear. I can honestly say the ride quality has not improved at all since the switch. I guess i need to try the full leafs in the rear.
finally dumped the Fox shocks went with Bilstien 5100’s ride has improved greatly.
20x9 method
295/65/20 Toyo AT
Awesome thanks! I saw yours up there but was unsure if they were the 20x9 or the 20x10. I really like the look of that. Would you happen to have a photo down the side to show how much the tires stick out?
maybe the width of 1 tread, that was my reason for going with that width, didn’t want anymore hanging out
Finally got my MR701's installed, 17x8.5 with Toyo MT's 35/12.5/17. Love the way the bronze looks with the Silver Spruce!
Day I had them installed Leg day at the lease filling feeders
At last someone has posted pics of the Method 701's, they look great :-) Just got a call from 4WP that my long delayed order is on the truck and should arrive soon. Waiting for black 701HDs, 18x9, +18ET.
Does anyone know if the Method NV 605 wheels are hub centric? Website says, “Hub centric fitments for common applicantions”. I am not to sure what that means. I really want wheels that are hub centric just like the factory platinum wheels.
I contacted Method Racing about the same wording re 701 HD wheels. Their response was that F150 wheels are hub-centric, but their Super Duty 8-bolt fitments are lug-centric.
looks like I will be contacting method today. I don’t know if I’ve seen other wheel descriptions that mention hub centric like the NV 605s.
Also, the factory platinum wheels hub bore size is 124.9mm and the NV 605 hub bore is 124mm. I am assuming the are hub centric.
***Update***
Spoke to method rep this morning regarding the NV605 wheels I was looking at for my F250. This wheel is actually a hub centric will according to the method rep. According to him, one would know it would be a hub centric wheel if the center cap is a bolt on cap and not a push through cap. Now with that being said the hubbore on the stock platinum wheel is a 124.9 MM and the hub bore on the NV 605 method wheel is a 124 MM.
I like the look of the hub caps in the front but I am afraid my auto 4x4 wont engage so I still want the option of using my manual lock function. Are you able to remove the front caps without taking your wheel off? I don't have my wheels yet since I am still on a 5 month waitlist for a Carli lift but trying to figure out if I will be able to do that.
Method NV HD 18x9 +18
Goodyear Duratrac 35x12.5x18
No lift or level but do have snow plow front springs
I was hoping the caps were a little easier to take off or get your hand into so I left mine off the front which seems to be about 50/50 here. No way I want to be guessing which Allen bolts are real or fake (only 3 actually hold the cap on) if I'm stuck and then it looks like you can barely get your hand in there if the cap is off.
Hi, wondering if there is any tire rub from this set up? Looks awesome!
I have the Method NV305 HD 18" for the 4500 lb rating with my truck camper on.
Tires are Toyo AT2 Extream in 295
I would like to see more up close pics of your wheel/tires. I too have a camper and am thinking i like that 295/70-18 tire combo. I like the Weight rating of the NV wheel.
I had a question...I am looking at getting a set of Method 305 NV, is it worth the extra $50 per wheel to get the HD version? I have a F250 coming in and don't know if I need the 4500 lb rating of the HD wheels vs the 3640 lb rating for my truck. Thanks!
