Fox single steering stabilizer
Old Jan 8, 2019 | 11:58 AM
  #31
catrasca's Avatar
catrasca
As per instructions and fitment guide on dual stabilizer kits, they only work on lifted/leveled trucks.
I got the Rough Country N3 Kit and it works great. Got rid of all bump steer and feels really tight. I left the stock stabilizer in it’s place after trying without it. A little bit of a workout for parking maneuvers and steering wheel doesn’t return to center as quickly on corners.
Rough Country N3 Dual Steering Stabilizer
Old Jan 8, 2019 | 12:13 PM
  #32
Rockinfigs's Avatar
Rockinfigs
Originally Posted by jlalanas
Yeah, I don't think most dual stabilizers (ones that mount on the axle) will fit on a non-lifted/leveled truck. Not enough clearance between the stabilizer and the steering components.
Exactly but FOUNTAIN man doesn't seem to understand that.
Old Jan 8, 2019 | 12:27 PM
  #33
F250inPA's Avatar
F250inPA
Originally Posted by daniel044
It would only ruin the warranty on the stock stabilizer. If you went to the dealer they may replace the stock one for you, I would just buy the fox stabilizer and replace it. I have had mine on for over a year and no issues at all. I have about 23k miles on mine as well.
I took your advice.
just ordered it from stage 3.
said they would let me know when it ships
Old Jan 8, 2019 | 12:28 PM
  #34
wicked 2018's Avatar
wicked 2018
Originally Posted by F250inPA
hello everyone.
I have a 2019 250 4x4 platinum diesel.
the only thing that I dislike about my truck is the bump steer over 65 mph.
if I were to change out the steering stabilizer will that give me warranty issues?
if I went to my ford dealer and asked them to address it what do you think would
be there answer?
No issue with warranty - your stabilizer will now be covered by Fox since it will be their stabilizer.
Dealer likely won't do anything unless you have real death wobble - then they would do the TSB fix, although with a 2019 - your truck probably has the "new and improved" factory stabilizer.
Old Jan 8, 2019 | 05:50 PM
  #35
FOUNTAIN 1's Avatar
FOUNTAIN 1
fountain man knows dam well . since I have duals on my kelderman lifted duelly , that can be slammed to lower than stock . so answer this mr mouth . how is that possible . as my single wheel kr also lifted, but cant compare that as it not an air ride truck . if you would like to meet somewhere and discuss this further rockman let me know, love to show you first hand !!.that it indeed will fit ..
Old Jan 8, 2019 | 08:33 PM
  #36
Rockinfigs's Avatar
Rockinfigs
Relax there internet tough guy..didnt mean to get you all mad..its just a discussion over a stabilizer. The OP does not want duals...hes looking for a stock replacement..we will leave it at that. No hard feelings
Your kelderman system probably replaces every component in the front end making a dual fit even when lowered..But on a straight stock truck a dual system will not fit due to clearance issue.
Old Jan 16, 2019 | 11:00 AM
  #37
whitre's Avatar
whitre
I installed a new Fox 985-24-001 Steering Stabilizer on my 2017 F250. It made a whole lot of difference!
The Ford put on new steering stabilizer on my pickup and it only lasted 5,000 miles! It was shot with 1/4 inch of play when I took it off! It had so much bump steer that I can’t stand it! I’m so glad I went with Fox!
Ford, are you listening???? I wish Ford put Fox brand steering stabilizer on new pickups as a standard equipment!
Old Jan 16, 2019 | 11:24 AM
  #38
Tedorama's Avatar
Tedorama
Originally Posted by dnhrdng
you can get the King stabilizer for about 250 heavier unit. but I don"t think you will need it unless doing some heavy duty off roading
Go for the KING
Old Jan 16, 2019 | 11:28 AM
  #39
whitre's Avatar
whitre
Do you like King better than Fox? Last longer?
Old Jan 16, 2019 | 11:37 AM
  #40
Tricon's Avatar
Tricon
He has no idea what he's talking about. The Kelderman setup uses a completely different sway bar setup, which is why you can raise and lower it so much. You cannot use a dual axle mounted stabilizer on a stock truck. You'll bash that thing off the first speed bump you hit.
Old Jan 16, 2019 | 12:05 PM
  #41
Bombero's Avatar
Bombero
fountain man knows dam well ....
You know it’s getting serious when it’s gone third-person references!! 😆😆😆😆
Old Jan 16, 2019 | 07:56 PM
  #42
FOUNTAIN 1's Avatar
FOUNTAIN 1
I guess so ,, lol I guess I must be wrong ,, it doesn't look whole lot different under the two trucks to me lol but im probly mistaken ..
Old Jan 16, 2019 | 08:04 PM
  #43
FOUNTAIN 1's Avatar
FOUNTAIN 1
ya know , more I think about it , I haven't owned a stock truck ever that I can remember , 20 plus new lifted n counting . I vary may be wrong . sorry rockman
Old Jan 16, 2019 | 09:04 PM
  #44
Rockinfigs's Avatar
Rockinfigs
No hard feelings.. We are all ford family here trying to help each other out.. It's all good 😉
Old Jan 17, 2019 | 11:49 AM
  #45
dave91gt's Avatar
dave91gt
Thought I'd add what others have already confirmed. I just called FOX directly and they verified the 985-24-001 single stabilizer WILL fit 17+ trucks. They are updating their website.
The only caveat is if you receive one with the bump spacer, simply cut it off. It is not needed.
