Fox single steering stabilizer
Old Mar 19, 2019 | 10:22 PM
  #106
hobbie1's Avatar
hobbie1
Originally Posted by Tricon
If your stabilizer has too much pressure in it, it can do as he said. Brand new it might push a little, but after its broken in it'll be perfect. Mine never pushed, my neighbors did, after about 500 miles he said it completely went away. I'm still a firm believer in the single being the best route you can go.
Curious - is your suspension stock? What LBS are you running on the unit?
Old Mar 19, 2019 | 10:47 PM
  #107
llmflyfisher's Avatar
llmflyfisher
for 2019 also?
Originally Posted by Carnac22
I ordered this one from Amazon for my 2017 stock (no level or lift) F-250 Platinum 4x4 Diesel:
Fox 985-24-001 Steering Stabilizer. It cost ~ $148 with free shipping.
Easy install (got a Lisle 41970 heavy duty pitman arm puller at the same time - made removing the factory stabilizer easy).
Fits well - improved front end stability and steering wheel feed-back.
Very nicely made.
Jim
Will this part number fit on the 2019 model as well? Assuming it would, but wanted to make sure.
Old Mar 20, 2019 | 05:43 AM
  #108
09FX-4's Avatar
09FX-4
I put this on my 2019 with no issues. Works great.
Old Mar 20, 2019 | 09:14 AM
  #109
llmflyfisher
Thanks
I ordered one this morning from Amazon. I want to swap out the stock shocks with some Fox 2" which was the main reason I did not order the FX4 package. Figured i would use that money and put some good shocks on it. No plans to lift level drop or anything else. Truck looks awesome to me just the way it is. Someday prolly install an aftermarket track bar but not any time soon.
Coming from my old 2006 dodge this truck is light years from that. I need to read the manual to figure out how to use everything. And I want to turn off that darn adaptive steering or whatever it is that slightly shakes the steering wheel every time I do a lane change. I really hate that.
Old Mar 20, 2019 | 09:15 AM
  #110
llmflyfisher
Thanks
Old Mar 20, 2019 | 09:30 AM
  #111
Joe T's Avatar
Joe T
My ATS came in, took a couple months. Stage3 was friendly and sent reminders but didn’t answer my question on what fox 2.0 shocks should I use on my truck with heavy service front springs. I assume they have a different rate and sit a good half inch or so higher.
Anyone know? I dont want to highjack the thread.
Old Mar 20, 2019 | 10:00 AM
  #112
jlalanas's Avatar
jlalanas
Joe, You sould be fine using the Fox Shocks for 0-1.5in of lift. That's what I did and I have a 1.5in level kit in my truck. Curious if anyone feels differently.
Old Mar 20, 2019 | 10:41 AM
  #113
Joe T's Avatar
Joe T
Perfect thanks.
Anyone have the part numbers handy?
Old Mar 20, 2019 | 09:06 PM
  #114
Bucsfan69's Avatar
Bucsfan69
I did my single about 3 weeks ago, just the pitman would not budge it, had to spray some blaster on it then heat it,,. Popped right out using the puller without even having to tap it. My fox gave me a pretty good left pull after install, after purging about 1 second of the charge. It’s perfect
Old Mar 21, 2019 | 02:46 AM
  #115
LAPII's Avatar
LAPII
For ATS install are there any tricks or precautions to take, guys that have done it themselves?
Old Mar 21, 2019 | 11:19 AM
  #116
wicked 2018's Avatar
wicked 2018
None. I used blue loctite on pinch bolts. And it's almost necessary to have a helper to hold the steering wheel at lock to get the 1/8" measurement they want, simply turning it yourself does not max it at lock.
Old Apr 7, 2019 | 11:49 AM
  #117
BigKahuna68's Avatar
BigKahuna68
Maybe I'm missing something here, but I'm puzzled as to the 'new' IFP 2.0 single stabilizer. I've seen pictures where the arm end comes with the necessary bushings, spacers and bolt as a simple replacement to the Motorcraft OEM one. Other pictures I've seen are of just the stock shock; no hardware. I ordered one from Amazon just last week. All I got was the raw shock. The frame end is straightforward; its the arm end that puzzles me.
I pulled to OEM one off thinking that I can just remove the bolt, etc but the end is tapered for about a 5/16" or 8MM wrench and not sure I can get enough torque on that thing to get it off without bending or breaking something. Frankly don't know if that assembly even comes off.
Am I missing something or should I continue to try to get the old hardware off the OEM to put on the new shock?
Old Apr 7, 2019 | 11:54 AM
  #118
timritchieblue's Avatar
timritchieblue
you are missing the hardware,package, the Fox S.S. comes with everything you need. I don’t believe the stock tapered bolt comes out of the shock.
Old Apr 7, 2019 | 12:58 PM
  #119
BigKahuna68
Yeah I think I got the universal fit version and not the Ford SD specific -001 version. The outer box clearly states Ford SD SS 985-24-001. So don't know if Fox is putting wrong parts in the wrong box or someone forgot to put the hardware kit in the box. Regardless back to Amazon it goes and I'm placing my order elsewhere.
Old Apr 7, 2019 | 07:37 PM
  #120
MBaldo's Avatar
MBaldo
Went with the double. It really improved the ride.
