Transfer case motor not activating
i have manual locking hubs and have changed nothing between when it worked and when it didn't other then having the leak. The water appeared to only get on the 2 big plugs on back of the fuse panel. I removed, contact cleaned it and reassembled. Everything but the 4x4 worked fine after drying and reassembly. I also inspected the GEM and it did not appear to have any signs of water intrusion directly.
i checked fuses .. they are fine
I checked voltage at the motor plug and dont seem to get anything as the switch is cycled
I can't hear any switchjng of the relays by the fuse panel under the hood.
Any suggestions on tracing this down? i looked at a wiring diragram and the motor activation doesnt look like it passes through the gem. Could this be a gem issue, or could it be in the under dash fuse box that got wet? There's no fuses in there dedidated to the motor that i can see in the manual
the dash light does not come on.
https://www.ford-trucks.com/forums/8...ot-engage.html
this one talks about the actual transfer case going bad
https://www.ford-trucks.com/forums/9...need-help.html
I think I've narrowed it down to the relays or the switch itself. My confusion comes in that some seem to say the GEM plays a role in it, and others do not. I also dont see the GEM in the wiring diagram for the motor. It seems like an odd coincidence that the 4x4 doesnt work after the fuse panel ... and maybe the GEM got wet.
i guess the real question is... can i eliminate the GEM or under dash fuse box as a source of the problem becuase they don't play a role in controlling that motor?
I have posted some extensive info down in the 7.3L section over the last few years, to include the whole theory of operation section from the manual, and the troubleshooting steps.
