4-wheel drive will not engage
Old Dec 17, 2008 | 01:50 PM
Jager's Avatar
Jager
I have vac. hubs and I can here a clunk noise when I turn the switch but the 4 wheel drive will not ingage. I jacked up the front end an engaged the 4 wheel drive but the front wheels will not move in drive or reverse. Please help............. snows getting deep
Old Dec 17, 2008 | 01:52 PM
60RatRod's Avatar
60RatRod
Need a little more info. Is the 4x4 light coming on in the dash? Is the heater blowing through your dash vents or defrost vents? you may have to amnually engage your hubs for now.
Old Dec 17, 2008 | 02:27 PM
Jager's Avatar
Jager
light comes on, heater works, will not ingage 4 hi or 4 low, drive shaft will turn when front of truck is jacked up and in "N". All fuses are good.
Old Dec 17, 2008 | 02:34 PM
60RatRod's Avatar
60RatRod
O.K. Im not sure here are a couple of links to read on they may or may not help
Welcome to guzzle's 4x4 Needle Bearing Maintenance Web Page
Im sure someone will jump in here with a possible answer.
Have you tried to manually engage?
Old Dec 17, 2008 | 02:55 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Put the truck in 4x4, then climb under the truck and see if you can turn the front driveshaft. If it turns, the transfer case is not engaging. If the driveshaft does not turn, try turning the joints at each wheel. If they turn then you know it is the hubs that are not locking.
Old Dec 17, 2008 | 03:55 PM
Jager's Avatar
Jager
Jacked the front end up with 4 wheel Dr turned on and in Drive. Tried to turn the drive shaft by hand but it would not turn. Turned 4 wheel drive off and put it in Neutral and turned drive shaft by hand and both front wheels turned.
Old Dec 18, 2008 | 10:39 AM
husker's Avatar
husker
I have a similar issue. I did Guzzle's R&R of the needle bearings etc. A couple of days ago when it was nice and cold and we had snow the 4x4 would not work even locking the hubs manually. When I switch into 4x4 Hi with the engine off the front driveshaft will not turn. Turn it off and the shaft will turn. It will also shift into 4x4 low, but still now 4x4. My question, will the hubs still not engage manually if there is a problem with them?
Old Dec 18, 2008 | 11:38 AM
PaysonPSD's Avatar
PaysonPSD
If you put the hubs in the lock position they should be locked just like manual hubs regardless of any vacumm leaks. If you can turn the axle shaft by hand when hub is in lock position then the hub is not manually locked.
Old Dec 18, 2008 | 07:02 PM
husker's Avatar
husker
If you can turn the axle, does that mean the hub is not locking manually and is probably shot. I also assume if one hub is bad, then with an open front differential there is no 4wheel drive.
Old Dec 20, 2008 | 02:23 PM
Jager's Avatar
Jager
My problem ended up being both relays were out. Hope that will help anyone else out.
Kevin
Old Dec 20, 2008 | 09:32 PM
husker's Avatar
husker
I think the transfer case motor isn't working. I changed the relays around but that didn't help. It has been too cold to crawl under it and tear things apart, so I've just been using the old beater 78 Bronco. I had to use it to tow a delivery truck up our steep driveway today after he got stuck on the ice.
Old Dec 21, 2008 | 10:13 AM
zbd74's Avatar
zbd74
Kevin
Could you share which relays, and where they were located?
Old Dec 21, 2008 | 10:22 AM
PaysonPSD's Avatar
PaysonPSD
This is where the ESOF relays are on my 1999. This should be the same for 2000 & 2001. 2002 & 2003 have different fuse and relay locations. Check your owner's manual.
EDIT: You can get an online manual HERE.
Old Dec 21, 2008 | 10:27 AM
husker's Avatar
husker
My 'O1 has two sets of relays. There is another box next to the brake reservoir closer to the fire wall oriented verticle to the one in the picture.
Old Dec 21, 2008 | 10:37 AM
rebelchevy02's Avatar
rebelchevy02
The info in the first statement, means infact, that your transfercase shift motor is fine. Jack up one or both tires, have the truck in 4WD, and park, and lock in both hubs manually. IF you turn one wheel, and have both sides jacked up, the other wheel, should spin opposite of the direction your spinning it. If you have the other wheel on the ground, you should only be able to turn that wheel, untill both hubs lock in, which may take a quarter turn or so.
Theres a couple things to look at then. With both hubs manually locked in, and after youve turned the wheel a little, if the other side doesnt turn (with both sides in the air) or you can completely turn the one side (with the other end on the ground) look to see which axleshaft is not turning. And that will tell you which hub is bad. The fact you said you heard a pop, could have just been the transfercase motor shifting a little hard, but it also could mean you popped a hub. Try this, and get back to us.
