2018 door locks freezing
Old Nov 15, 2018 | 08:53 PM
ArcticCircle's Avatar
ArcticCircle
I just went through this on my 17 Platinum. Last year, they replaced the entire latch mechanism on all the doors. This year, first night of freezing temps, it did it again. Doors wouldn’t latch. I had to drive 30 min to work, holding the door closed with my hand. Next morning, door latched but not completely and swung open as I turned a corner. I called my dealership and threw a fit with the service manager. Lawsuit city I told him, because that’s exactly what that is. Unbelievable for a $65K truck. I brought it in, and they siliconed a bunch of stuff, and so far, so good now. We’ll see if it holds up. You’ve got to press them on safety matters such as this. Good luck.
Old Nov 24, 2018 | 12:27 PM
delorenzomp's Avatar
delorenzomp
so, does anybody what Ford is doing when taken under FSA18N03 ? I think that DIDit4DAD has a good idea, spray the latches with Fluid Film...obviously Ford thnks that the latch is the issue having replaced them for a poster, but when it did not remedy the freezing I think the addition of Fluid Film may be worth a try...
Old Nov 24, 2018 | 12:49 PM
LiquidSteam's Avatar
LiquidSteam
Originally Posted by cob1181
I have a 2018 F350 cclb. Yesterday morning the temperature was 30 degrees. I opened my doors to load up my truck and the rear passenger door would not latch until several hours later once temps got above freezing.
I had this same problem with my 2015 which was recalled. I read that the recall was also for the 2017 super duty as well.
Has anyone experienced or heard of door lock issues with the 2018's?
This happened with the drivers door on my 2017 the other morning. I hit the mech with some T-9 and all fixed.
Old Nov 24, 2018 | 01:58 PM
ecoboost12's Avatar
ecoboost12
Hi, What is T-9 ? I've used the Fluid Film and so far its working, I've also used Lock Ease (liquid Graphite) in a spray can
Old Nov 24, 2018 | 03:40 PM
Mkos1980's Avatar
Mkos1980
One week old 19 with 181 miles on it and I couldn't get my door to latch as well. Truck not listed for the voluntary recall as well. Drove my old Silverado to work...
Old Nov 27, 2018 | 07:38 AM
JackalAR's Avatar
JackalAR
My 2017 w/ 9,300 mi. is doing it on both rear doors this AM, real fun with my 9 y/o sitting back there. Called the dealership a month ago about it when it was still nice and warm out, and they told me that they wouldn't touch it until I actually had an issue. First of all I don't trust them to do any major repair work, second of all I'm not convinced that w/e they are doing is actually addressing the issue. Does anyone have any success stories?
When one's door flys open going around a corner, is the door / hinges damaged?
Old Nov 27, 2018 | 07:53 AM
6.2caribou's Avatar
6.2caribou
My experiences with this issue always initiated with the truck at rest, never in motion. If it ever happens while in motion, I will document as best I can and then will immediately attempt to inform NHTSA.
Old Nov 27, 2018 | 07:56 AM
JackalAR's Avatar
JackalAR
Just hung up with the Service Department, they gave me the same line of crap that they did last month, they state that the voluntary recall is in regards to the door latches freezing closed, not allowing you to open the doors. I communicated my frustrations and let them know that they were misleading people on this. She checked with a Service Manager and they said that I could bring it in as early as tomorrow for latch replacement and the weatherstripping work on both rear doors and that it should only take 1 full day to complete the work. They will not address the front doors until there is an issue with them and since the 9 y/o sits in back. I guess old people lives don't matter. Still skeptical that this is an actual fix though. Any idea if there has been a part number supersedence?
Old Nov 27, 2018 | 08:41 AM
delorenzomp
Does letting the heater run for a given amount of time ? 30 min? do the trick of making the latch work? Or spraying it with a water/moisture displacement substance not at that time of it not working but as a preventive measure...?
Old Nov 27, 2018 | 11:25 AM
JackalAR's Avatar
JackalAR
One of my doors did it after a 10-12 min. warmup with heat and blower on high, the other one did it about 20 min. later so the vehicle was plenty warm inside. I got both to latch by repeatedly shutting them and cussing vigorously.
Old Nov 27, 2018 | 11:34 AM
delorenzomp
thanks, JackalAR...so, maybe there is some binding in the system, 'behind the scenes'...my guess would be to fluid-film the inside through an existing hole or create some in the end of the door, and spray the exposed latch...this is unacceptable to be occurring once it became known. I will be ordering a 2019 soon and cannot believe that I may have this to look forward to.
Old Nov 27, 2018 | 11:51 AM
JackalAR's Avatar
JackalAR
Yea that is pretty mind boggling that this is still an issue.
Old Nov 27, 2018 | 02:34 PM
  #28
Platinum08's Avatar
Platinum08
Originally Posted by delorenzomp
So, if there is a TSB and/or FSA issued on a problem for which there is an identified problem and an identified remedy but not necessarily an assembly line corrective action, and I order an affected vehicle, is the work performed prior to me taking delivery? or not necessarily so...thanks.
When I picked up my new truck it had not been reflashed for the tsb for the electrical draw when operating a plow. I assumed they didn’t do it since it only happens when you install a plow.
Old Nov 27, 2018 | 03:22 PM
  #29
delorenzomp
Thanks, platinum08, I can see that perhaps in the case of having to add a plow, but I’d like to see them just step up and take care of business.
Old Nov 27, 2018 | 03:29 PM
  #30
JackalAR's Avatar
JackalAR
I don't know much about plowing, but I'd like to think that if I were to get into it, that I would do a self install at some point down the road, and I'd be mighty pissed about this current draw situation that I probably didn't even know about.
