2018 door locks freezing
I have a 2018 F350 cclb. Yesterday morning the temperature was 30 degrees. I opened my doors to load up my truck and the rear passenger door would not latch until several hours later once temps got above freezing.
I had this same problem with my 2015 which was recalled. I read that the recall was also for the 2017 super duty as well.
Has anyone experienced or heard of door lock issues with the 2018's?
The dealership won't do anything because the recall doesn't cover the 2019, even though they have had a dozen people in with the problem. I've called Ford and escalated this as much as possible, no word yet.
It's not a recall. It's a Field Service Action (FSA). The FSA on this issue is FSA 18N03.
A recall occurs when the NHSTA forces the manufacturer to do something, and it is almost always a serious safety-related defect (think: Takata air bag recall)
FSAs are voluntary recalls, not forced by the NHSTA. Think of these as "recalls that Ford is doing BEFORE the NHSTA forces them to do them". You should be notified by Ford the same way you would be notified for a recall.
Ford also issues TSBs (technical service bulletins). They are not MANDATORY, but instead are issued when a known problem or condition exists in a certain vehicle or group of related vehicles. You vehicle may or may not have the condition and, therefore, may or may not be "fixed". If your vehicle is under warranty, the manufacturer pays for the work. If you're OUT of warranty, YOU get to pay for a TSB repair (if performed). Ford doesn't typically notify owners directly.
There's actually another: SSM aka Special Service Message. This is when Ford knows there is a problem, but has yet to determine a solution. These usually precede a TSB or FSA.
Second, if the 2019 MY isn't on FSA 18N03, then the dealership won't do it because Ford wont' reimburse them (the manufacturer reimburses dealerships for both recalls and FSAs).
Thanks for clarifying that about the FSA vs an actual Recall. My Ford Pass app shows that FSA 18N03 for my 2019 F250 but I'm not having any door latch freezing problems. The truck sat outside last night with the temp around 10 degF with around 50% humidity and didn't have any latch issues.
So, if there is a TSB and/or FSA issued on a problem for which there is an identified problem and an identified remedy but not necessarily an assembly line corrective action, and I order an affected vehicle, is the work performed prior to me taking delivery? or not necessarily so...thanks.
