66 ignition switch original harness plug wiring help
Old 10-15-2018, 01:11 PM
Gsf35099's Avatar
Gsf35099
Gsf35099 is offline
Need some help please. The original owner cut the original plug for the ignition switch and I’m looking for the wire configuration of the original plug as I have a replacement switch that takes the original plug and there is no markings on the new switch as to what the lugs are.
I’m betting someone here has the wiring configuration of the original plug so I can determine what wires to plug where on the new ignition switch.
Ultimately I would like to find an original plug and put it back.
Thanks in advance with any help.
Old 10-15-2018, 02:07 PM
Crop Duster's Avatar
Crop Duster
Crop Duster is offline
Old 10-15-2018, 02:48 PM
Gsf35099's Avatar
Gsf35099
Gsf35099 is offline
Originally Posted by Crop Duster
Thank you very much. Cool site I didn't know was out there.
Now to find the wiring diagram for that plug.
Old 10-15-2018, 04:38 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Jolly Roger Joe is offline
Will this help?
http://www.fordification.info/tech/i...ngcharging.jpg
Or maybe this one?
http://www.fordification.info/tech/i...sterwiring.jpg
Old 10-15-2018, 06:17 PM
Gsf35099's Avatar
Gsf35099
Gsf35099 is offline
Originally Posted by Jolly Roger Joe
Thanks Joe. I thought that first one might do it, but neither unfortunately show where the 4 lugs on the ignition switch go that will help me know which lug is battery, ignition, accessories. I'm assuming the ground is the center post as it looks like the trace goes into the switch, but I'm almost betting the 4 lug on the switch is ground as well. Just not sure.
Hopefully, there is a diagram out there that will show the socket wiring.
Old 10-15-2018, 06:43 PM
resonateur's Avatar
resonateur
resonateur is offline
...once you wire the new pigtail to your wiring harness, I believe there is only one way the plug can connect to the ignition switch.
Old 10-15-2018, 06:53 PM
Gsf35099's Avatar
Gsf35099
Gsf35099 is offline
Agee, but I need to know how to wire the new pigtail socket. I'm going to purchase the new pigtail socket from LCM and hopefully the wire colors will help or keep searching for a diagram that will show that socket.
Old 10-15-2018, 07:04 PM
daveengelson's Avatar
daveengelson
daveengelson is offline
Not sure if any help?, thought I would throw in another link to confuse the issue?
Old 10-15-2018, 07:15 PM
Gsf35099's Avatar
Gsf35099
Gsf35099 is offline
thanks Dave. I just found this exact one and pretty sure that top diagram will do it.
Old 10-15-2018, 09:59 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
There are TWO possible ignition switches, which one did you get?
In 1967, Ford replaced the original 1961/66 switch (C3AZ-11572-A [replaced C0AZ-11572-A] Motorcraft SW-353) with the '67 Bronco/Econoline switch (C7UZ-11572-A/Motorcraft SW-583) that has an extra terminal.
The original switch was also used on 1960/64 Galaxie; 1961/64 Thunderbird; 1965/66 Mustang.
Note: Dave's 1st diagram in post # 8 titled EARLY IGNITION SWITCH is actually the LATE 4 terminal switch, because the brake warn(ing) lamp was introduced in 1967.
Old 10-15-2018, 10:37 PM
Gsf35099's Avatar
Gsf35099
Gsf35099 is offline
I got the late switch with the 4th terminal that I figured wouldn’t be used.
Appreciate all the help and hopefully the socket pigtail I ordered will fit. At least the diagram shows the wiring of the switch. Can make it work now.
Old 10-20-2018, 03:44 PM
Gsf35099's Avatar
Gsf35099
Gsf35099 is offline
Really appreciate all the help & wanted to post an update and ask one more question.
New switch, bezel, & socket plug wired and installed & working really well.
Is there a large grommet or something similar that is supposed to be put on the ignition switch that helps push it away from the inside of the dash? I modified a piece of pvc to hold the switch back to apply pressure so the bezel & switch stays in place.
Old 10-20-2018, 06:29 PM
NumberDummy
Is there a spacer that is supposed to be put on the ignition switch that helps push it away from the inside of the dash?
C1TF-10A885-A .. Instrument Cluster Control Mounting Plate (this is the spacer between the switch and the backside of dash) / Obsolete
1961/66 F100/1100 & C550/1100 Tilt Cabs; 1961/67 Econoline; 1963/69 N/NT500/1100; 1967/69 F800/1000.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 2,906 (!) = 800-476-9653.
See 10A885 in pic:
Old 10-20-2018, 06:32 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Old 10-20-2018, 06:53 PM
Gsf35099's Avatar
Gsf35099
Gsf35099 is offline
Thank you Bill. Really appreciate the help.
Kaven
fatheroftwo
04-10-2017 11:48 AM
URDADDY
02-23-2012 10:31 PM
RUSTY50F1
13
03-21-2009 04:16 PM
Jaaaaaaackman
03-02-2008 11:01 AM
francb
01-31-2004 06:31 PM
Quick Reply: 66 ignition switch original harness plug wiring help
