Death Wobble Poll?
Old Oct 15, 2018 | 11:42 AM
  #76
'18_F250_4x4's Avatar
'18_F250_4x4
Originally Posted by JP-8
Maybe i'm crazy... you weren't asking for anyone's personal experience with death wobble... you were asking for instructions on how to setup a poll and if anyone had suggestions about the questions you were proposing?
I would greatly appreciate a poll and I think your questions are very good. I might add:
What year is your truck?
What year did you first encounter DW?
How many miles were on your truck when you first encountered DW?
Very interested in the results. I have had a little experience with surveys. As soon as you deviate from yes/no or multiple choice your poll results can become more difficult to read and graph so most polls try to avoid fill in the blank when possible. You could do years in groups of 5 (i.e. 2015-19, 2010-14, 2005-09, 2004 or older) or years by body style would probably be more appropriate (would require a little research). You could break up the miles in increments of 20k.
Would also limit poll participation to registered users to increase the level of effort required for some dodge/chevy nut to wreck your results.
Again, very interested, keep us posted.
JP-8
Thanks for the thoughts and agree with many of your points. I was asking both questions really; can I post a Poll via this site (there is an option) and if there were questions the group thinks would be good to include. Working a survey now... more to come.
Old Oct 15, 2018 | 11:57 AM
  #77
'18_F250_4x4
Originally Posted by AquaMancw
Update to the TSB 18-2268
So far absolutely zero wobble. Same highway driving, Denver to Colorado Springs, and Denver to Ft. Collins, zero death wobble. Very smooth, the truck drives great again.
caster set to L/F +2.8 R/F +2.4, adjust front toe +.04, R/F +.05.
On a side not they had to replace my sync APIM as well.
Dealer - "Ford covered the $428.37"
Me, no I prepaid 70k for Ford to fix it
Good to hear and let's hope it stays that way!!
Old Oct 15, 2018 | 12:01 PM
  #78
hindy's Avatar
hindy
It would be interesting if the death wobble was better/worse with different front spring ratings, snow plow, camper packages, etc.. Could be totally irrelevant but thought I would throw it out there.
Old Oct 15, 2018 | 01:36 PM
  #79
'18_F250_4x4
I will build a survey based on the flow chart, any thoughts on additional "questions" or conditions to add?
Old Oct 15, 2018 | 01:57 PM
  #80
Maximus216's Avatar
Maximus216
I experienced a death wobble in my 2018 F250. The dealer advised that my steering damper is bad. Getting it replaced under warranty.
Old Oct 15, 2018 | 04:37 PM
  #81
hindy's Avatar
hindy
Looks great!! I think the only thing you' re missing is truck color, just messing around 😁.
Old Oct 15, 2018 | 08:50 PM
  #82
Chaserev800kid's Avatar
Chaserev800kid
All these “death wobble” trucks and the ones with legitimate death wobble need is more positive caster. That’s it done deal easy to have done. Ford doesn’t put enough caster to help keep the steering light. You don’t have to go crazy with it either. I’ve had legitimate death wobble in my 07 Cummins and fought it for months until I figured the caster issue out. Had to find a shop that was willing to align it a few degrees more than factory spec and bam no more death wobble. The truck felt so much more stable on the road didn’t eat up tires or other components, I drove it 100k miles after the fix and other than normal dodge stuff no issues. With my 17 Powerstroke when it was stock it drove great unless you hit bumps around corners and stuff. Didn’t feel very stable and why I never had real death wobble I did get the steering wheel shimmy which made you feel very unconfident. I put a carli 2.5 back country kit on my truck and had the caster adjust 2 degrees past factory spec and it’s been the best driving truck I’ve owned to date. Just my 2 cents take it as you want.
Old Oct 16, 2018 | 12:52 AM
  #83
'18_F250_4x4
FTE's
Here is the first DEATH WOBBLE survey, please let me know if it works and if you have questions that you think we need to add...
https://goo.gl/forms/GUDBzMzN5tKkHVm52
Old Oct 16, 2018 | 12:55 AM
  #84
ronf38's Avatar
ronf38
Unless your dead. It can only be a near death wobble or better
Old Oct 16, 2018 | 12:58 AM
  #85
'18_F250_4x4
True that... Maybe I should change the title...
Old Oct 16, 2018 | 10:10 AM
  #86
'18_F250_4x4
Pinned or Sticky Post
Question for the site ADMINS:
Can this post be "pinned" or "sticky(ed)" so the attached Death Wobble survey is easier to find?
Would it be better to post just the survey link and "pin" that post to the top?
Thank you!
Old Oct 16, 2018 | 10:30 AM
  #87
BigChief1's Avatar
BigChief1
Experience Death wobble first time yesterday 10/15/18. 2017 250 4x4 diesel 14,000 miles no modifications . Appointment next week at dealership. Scared the sh$t out of me now I won’t drive my truck 😡 not looking forward to wrestling with dealer for repairs.
Old Oct 16, 2018 | 11:44 AM
  #88
'18_F250_4x4
NOT COOL and glad you did not get physically hurt. Just advise them of the TSB listed in this thread and there should be ZERO push back from them. The way I see it is if you bring this to their attention and they do not comply with the TSB then they could/should/will be held liable if there were to be a crash after refusing to fix the problem.
Did you see the survey link in this thread? I will post the results in a few days but already seeing some good data points...
Good luck with the dealer and if they do push back ask them to have their wife of kids come down and drive the truck around for while... THAT should get their attention!
Old Oct 19, 2018 | 08:59 AM
  #89
'18_F250_4x4
Survey is active
FTE's
We have gotten some good responses and need more to get a good read on the issues.
We need both side of this issue 1) if you have experienced DW and 2) if you have not had the pleasure of DW.
THANKS
Old Oct 19, 2018 | 09:02 AM
  #90
ronf38's Avatar
ronf38
6 ford SD since 2011.....no wobble...all f350 and f450 cc lb drw 6.7 4x4
