Death Wobble Poll?
Old Oct 1, 2018 | 10:39 PM
  #31
'18_F250_4x4's Avatar
'18_F250_4x4
WOW Some GREAT looking trucks and pretty dang awesome info here!!!
OK so far there is a TSB that addresses this; thanks AquaMancw waiting for an update on that and the idea the 6.7 is a heavier engine so more weight on the front axle of the Diesel equipped trucks.
Of those who have experienced the dreaded (announcer voice) Death Wobble.... How many of you are running the 6.7 vs 6.2?
Sounds like shocks and stabilizers are the go to fix...
Old Oct 2, 2018 | 03:40 PM
  #32
sky Cowboy's Avatar
sky Cowboy
My businesses have had many F150, F250, and F350 trucks, many years and models, driven by dozens and dozens of people, with everything from no load to overloaded, and when I ask them not one has ever had the experience of a death wobble.
Old Oct 2, 2018 | 05:34 PM
  #33
AquaMancw's Avatar
AquaMancw
Got my truck back, took it for a spin on the highway did not get any wobble, yet.
TSB 18-2268 casual part 3E651
They also adjusted the caster, and camber toe in.
Other parts listed on the invoice
FMC 5c3z 3B440 EEE
FMC F2TZ 3A049 A
FMC 52528 S437 - PIN
FMC HC3Z 3E651 D
Old Oct 2, 2018 | 09:53 PM
  #34
'18_F250_4x4
FMC 5c3z 3B440 EEE
FMC F2TZ 3A049 A
FMC HC3Z 3E651 D
Looks like shocks, steering damper and camber or all the noted repairs that have "fixed" this issue. Hope you never get DW again!!!
Old Oct 2, 2018 | 11:13 PM
  #35
wicked 2018's Avatar
wicked 2018
TSB # 18-2268
Model: Ford
2017-2019 F-Super Duty
Issue: Some 2017-2019 F-250/F-350 4WD vehicles built on or before 31-Jul-2018 may exhibit a sustained steering wheel oscillation after driving over rough pavement or an expansion joint above 45 mph (72 Km/h).
Action: Follow the Service Procedure steps to correct the condition.
Parts
Part NumberDescriptionQuantity
HC3Z-3E651-D
Steering Linkage Damper1
5C3Z-3B440-EEE
1º Adjuster Assembly2
5C3Z-3B440-DDD
3/4º Adjuster Assembly2
5C3Z-3B440-CCC
1/2º Adjuster Assembly2
5C3Z-3B440-BBB
1/4º Adjuster Assembly2
F2TZ-3A049-A
Castle Nut2
W525288-S437
Cotter Pin2
Old Oct 2, 2018 | 11:14 PM
  #36
wicked 2018
Can you post the alignment spec sheet? Curious what they dial in caster, camber and toe to.
Old Oct 2, 2018 | 11:36 PM
  #37
willynilly's Avatar
willynilly
there you have it folks. ford is admitting theyre fully aware the '17-'19 trucks have death wobble. cut and dry in black and white
Old Oct 3, 2018 | 11:09 AM
  #38
Florit17's Avatar
Florit17
Yep, it can happen, just like it can happen to every other straight axle front end vehicle out there.
I've had the trucks listed in my sig below - The '12 F350 (stock suspension) was the only one that had issues with death wobble, twice in 60K miles, both times cured under warranty with multiple new front end suspension parts each time. BTW, if you ever have experienced DW, you will never say something like "I think my truck has DW" - It is such an extremely violent event that you will have no doubt what it was after it happens.
Old Oct 3, 2018 | 11:34 AM
  #39
EGoodie21's Avatar
EGoodie21
No Death Wobble for my 2017 F-250 XLT with 8800 miles. The suspension is completely stock, and no wheel/tire upgrades.
Just creaks in the doors when I lean my leg against it while driving.
Old Oct 3, 2018 | 01:51 PM
  #40
jackfordsd350's Avatar
jackfordsd350
2000 F 350 and 2017 F 350. No suspension mods and no wobble.
Old Oct 3, 2018 | 02:21 PM
  #41
bdmcdonald's Avatar
bdmcdonald
2017 F250 4x4 FX4, Camper pkg. never experienced death wobble, bump steer yes
Old Oct 3, 2018 | 02:57 PM
  #42
LaxPlaya21's Avatar
LaxPlaya21
2006 F250 XLT 4x4 SRW Short Bed Ext Cab Gas Stock Suspension: No DW
2006 F350 XL 4x4 SRW Long Bed Reg Cab Gas Stock Suspension: No DW
2006 F250 XLT 4x4 SRW Short Bed Ext Cab Diesel Front Level: No DW
2009 F250 Lariat 4x4 SRW Short Bed Crew Cab Diesel Stock Suspension: Yes DW
This truck like the others, was used for plowing. I think excessive front end wear was the cause, and there was no great solution. I replaced front end bushings and finally replaced the trac bar and that helped a lot. Steering stablizers also quieted things down. There was no way to fix the issue.
2013 F250 Platinum 4X4 SRW Short Bed Crew Cab Diesel Stock Suspension: No DW
2017 F350 Platinum 4X4 SRW Short Bed Crew Cab Diesel Stock Suspension: No DW
Old Oct 3, 2018 | 04:53 PM
  #43
willynilly's Avatar
willynilly
well like other people have said, somebody can get in a crash if they dont get it sorted out.
Old Oct 3, 2018 | 05:46 PM
  #44
WVSD's Avatar
WVSD
2017 F250 6.7 CC SB 4x4
camper package
18,400 Miles
stock height did add Rancho 9000XLs
has 285/65/20 BFG’s on Factory 20” wheels inflated to 65 PSI
No Issues
Old Oct 4, 2018 | 11:45 AM
  #45
TXKR's Avatar
TXKR
That is ABSOLUTELY the case.
Originally Posted by '18_F250_4x4
My poll would look like this:
Have you experienced DW? Yes or No . YES
If yes; Truck configuration? 4x4, 4x2, SRW, DRW . 4x4 SRW
If yes; Is your truck suspension stock or modified? STOCK
If yes; Did you find a fix? Shocks, steering stabilizer, tires, other____. Maybe sorta no..
Short version: My 2015 was flawless until 83k miles when it happened. Ironically, I was within a couple of weeks of trading it. My local dealer said nothing was wrong, so I replaced shocks and steering stabilizer with Rancho 9000s. It did it again on the way to trade it in. The trading dealer determined it was a worn steering stabilizer (though the new one was only 500 miles old.) Whatever....I just decided it as their problem and chose not to argue but knew they were wrong.
The reason I am so interested is because I can feel the same thing hiding inside this new truck. My 2015 KR had the towing package had race car-like steering and handling, no body roll, no bump-steer, no issue at all. This new truck has lighter front springs and exhibits front corner body lean/roll around the same corners I drove with the '15. I feel a lot of inputs into the steering wheel and on rough overpass transitions on the highway I can feel it wanting to wobble, though it hasn't yet. I have a lot of race car suspension experience, and have owned a numerous SFA vehicles. Obviously this is a design flaw, but truly curing it still seems to be elusive. My '18 has 5200 front coils whereas my new '18 has 5200. The shocks on the new truck seem much softer as well. So my plan is to upgrade coils to the same 5600 lbs that was on my '15 just to be able to compare, and then start looking into some caster correction, and lastly installing firmer Fox shocks and stabilizer. While I think installing shocks and a stabilizer is just masking the problem, I at least want cure the nose roll and evaluate the caster changes. I may even wind up at 6k front coils where you are. I think its a design flaw that cannot be corrected, but possibly isolated and contained.
