We got any beans for Sat. night?
Saw some smoked beans on Triple D the other night and wrote down the recipe.
Thought I might make a small batch to go in the smoker with the butt sat. Also bringing a small Cracker Barrel Mac n Cheese to smoke as long as Marty thinks there will be room in the smoker.
Tony, we'll work something out to get it on the smoker. Even if we have to rotate something, bring it on.
Bring on the beans. So far, people who have RSVP'd looks like we're going to have around 8, 9 counting *****, for grub on Friday and Saturday. I've only picked up 3 lbs of bacon, so I'm hoping someone else is getting some. But I know this group, so I'm not too concerned over food. I've got two chickens to stick on the grille on Friday. Think that'll be enough, or should I grab a third? I didn't grab any sides to go with that. I'm just worried we're gonna go hungry!
Where did you hear about the detour for Mullinix Rd. Like to find out if you can turn onto McCleans Creek or do you have to stay on Moccasin all the way to Badin Lake Rd.
Thanks. The washout is right at the intersection of Mullinix and McClean but it doesn't say if McClean is closed also. Just have to look for the signs I guess. If I get lost I'll call...
Sounds good. I assume that you come in from the North, where as we come up from the South. I think the road you will be looking for is past Eldorado Station, on the right, rather than before Eldorado station, where you used Mullinix Rd to get back in to the park. Other than that, it's not too bad. Probably stop in at Eldorado and they would be more than happy to provide a map and directions. Also, I believe you have my number. I'll check before I head out, to make sure I have yours, and if I run across anything I'll let you know ahead of time.
Tony, you might get there before I do. Decided to hit the dmv this morning as I needed to update my license.,15 minutes before opening, there was a line wrapped around the building at the local office. So I headed to the next county over. Shorter line, larger building, but I seriously think they have only two people working here.
Well hour one one has passed, without being called. Might should have brought my laptop, and worked this morning.
