Exhaust back pressure
Old Aug 27, 2018 | 11:40 AM
Travis Counts's Avatar
Travis Counts
What’s normal back pressure readings ? Thanks
Old Aug 27, 2018 | 01:22 PM
Ford.Dude's Avatar
Ford.Dude
Mine runs around 27 at warm operating temps and cruising speeds.
Zoom in to see lowest and highest values.
Old Aug 27, 2018 | 02:55 PM
navistarnut's Avatar
navistarnut
What year is the truck?
The early builds use an inferred value IIRC.
Old Aug 28, 2018 | 08:40 PM
KDAVID1's Avatar
KDAVID1
Yep...and you will know if it's bad on the later models. It will run horrible, will turbo fart, won't get to speed..you'll almost think it's a tranny problem.
Old Aug 28, 2018 | 08:57 PM
Travis Counts
It’s a 2004 my readings are 14.3 key on engine off 17.33 idle and 150 to 200 accelerating cruising its all over the map
Old Aug 28, 2018 | 08:58 PM
Travis Counts
It will only build about 14 psi of boost with the performance tune with a sct tuner
Old Aug 28, 2018 | 10:01 PM
navistarnut
How is the boost with the stock tune
Old Aug 29, 2018 | 08:42 AM
Travis Counts
Around 11psi I cleaned the sensor it wasn’t to bad but didn’t help I took the muffler off a long time ago but it still has converter on it I’m going to check it today
Old Aug 29, 2018 | 04:38 PM
navistarnut
Cleaning the sensor on the early build won't do much then, since it's an inferred value at the PCM.
IIRC the only way the EBP sensor will mess up an early build is if it shorts to ground or loses VREF.........someone else correct me if I am wrong please.
When is the last time the turbo was cleaned?
Checked all the boots and hoses for leaks?
Same for each and every exhaust connection from the manifolds all the way up to the y pipe collector?
Pulled the MAP hose off and cleaned the nipple on the intake? Hose itself is ok and not cracked?
Old Aug 29, 2018 | 05:00 PM
bismic's Avatar
bismic
That is the way I understand it, unless the flash update (came out in May of 2006) was never applied.
Old Aug 30, 2018 | 07:45 PM
Tcounts's Avatar
Tcounts
I doubt the turbo has been cleaned it is pretty rough sounding when I turn it off I thought about the cat being plugged and I will pull that map hose I’ve never done that either I appreciate the help guys
Old Sep 1, 2018 | 10:12 AM
AGE mechanic's Avatar
AGE mechanic
Do you have two profiles?
Based on the turbo "sounding rough", I think you have probably found a problem.
Old Sep 2, 2018 | 06:28 PM
Tcounts's Avatar
Tcounts
Yes I do I couldn’t sign in on my first profile so I created another . So you think it’s the turbo?
Stainless1974
Apr 12, 2018 04:26 PM
Mdkeehn13
Aug 31, 2014 10:34 PM
Gruntface
Apr 16, 2012 08:35 PM
DaFueler
Jan 15, 2007 06:01 PM
oldbird1965
Feb 17, 2006 10:40 PM
